2 Replies Latest reply on May 13, 2010 7:08 AM by sushiyum17
    Sequence setting for 720 by 1280i at 60 fps
    sushiyum17
      What is the best sequence setting for this? The closest 720 by 960, cutting off column information.
      Here is a properties print screen:
      File Path: J:\Boat Design files\Drift boat design\FILE0012.MOV
      Type: QuickTime Movie
      File Size: 36.5 MB
      Image Size: 1280 x 720
      Pixel Depth: 24
      Frame Rate: 59.96
      Source Audio Format: 48000 Hz - 16 bit - Stereo
      Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
      Total Duration: 00;00;49;11
      Average Data Rate: 756 KB / second
      Pixel Aspect Ratio: 1.0
      QuickTime Details:
      Movie contains 1 video track(s), 1 audio track(s) and 0 timecode track(s).
      Video:
      There are 2962 frames with a duration of 1501/90000ths.
      Video track 1:
      Duration is 0;00;49;12
      Average frame rate is 59.95 fps
      Video track 1 contains 1 type(s) of video data:
      Video data block #1:
      Frame Size = 1280 x 720
      Compressor = Ambarella AVC encoder
      Quality = Least (1.00)
      Audio:
      Audio track 1 contains 1 type(s) of audio data:
      Audio data block #1:
      Format = 16 bit - Stereo
      Rate = 48000.0000 Hz
      Compressor = MPEG 4 Low Complexity AAC
