3 Replies Latest reply on May 12, 2010 10:24 PM by Yuliaart
    Compound path  in InDesign CS4 JavaScript
    Yuliaart Level 1
      Hi, I need to create compound path from 2 overlapping rectangles, the top one subtracts from the bottom one and I could find anything in OMV, not sure where to look for it, didn't find anything the the forum so far. Could someone help me:
      var myBleedRectangleOutside = myDoc.rectangles.add();
      myBleedRectangleOutside.geometricBounds = [0, 0, myPageHeight, myPageWidth];
      myBleedRectangleOutside.strokeColor = myDoc.colors.item("Green");
      var myBleedRectangleInside = myDoc.rectangles.add();
      myBleedRectangleInside.geometricBounds = ["0.0625 in", "0.0625 in", myPageHeight -  0.0625, myPageWidth -  0.0625];
      myBleedRectangleInside.strokeColor = myDoc.colors.item("White");
      I need to subtract white rectangle from green.
      Thank you very much for your help.
      Yulia
        • 1. Re: Compound path  in InDesign CS4 JavaScript
          Yuliaart Level 1
          Corrections to my script:
          myBleedRectangleOutside.fillColor  = myDoc.colors.item("Green");
          myBleedRectangleInside.fillColor  = myDoc.colors.item("White");
          Actually I am even not sure if I need a fill color for my inside rectangle, because I want that part to be transparent when compound.
          Thank you.
          Yulia.
          • 2. Re: Compound path  in InDesign CS4 JavaScript
            "subtractPath", as in
            myBleedRectangleInside.subtractPath (myBleedRectangleOutside);
            It's the reverse of what I would thought it'd be, but it seems to work; switching 'inside' and 'outside' gives an "empty path" error.
            The bottom and right hand edges are mere lines, you need to make the bleed smaller by twice the necessary amount -- once for the left side, once for the right side.
            • 3. Re: Compound path  in InDesign CS4 JavaScript
              Yuliaart Level 1
              That's perfect, thank you very much.
              Yulia
