4 Replies Latest reply on May 12, 2010 4:52 PM by robinr303
    Is there a plugin to correct W3C Errors for xhtml ?
    robinr303
      I'm still working from CS3 so I'm not sure if Adobe CS5 performs better, but Dreamweaver isn't catching w3c errors. I know it's an issue for others on the forum, but all I've seen is "take out the apersands" and no long term solution to the other language barriers. I'm more of a designer than a developer but usually work comfortable in split code/design format. I just wish there were a resource I could refer to for standard js corrections.
      Here's an example of a page with 19 errors: http://www.3magicbeans.com/portfolio.html when run through http://validator.w3.org/check
      So, does this improve with CS5 or are we outta luck here?
      Thanks! Robin
