1. Re: Slide Show Audio Problem at Beginning of Show
Neil Wilkes May 13, 2010 6:33 AM (in response to jkb242)It sounds as if for some bizarre reason, the transition is causing the player buffer to empty out.
This happens on certain - usually older - players when sequential cells are set as non sequential in compiling.
(I had this one bite me - hard - recently, although from a different application).
Best way to check this is to go get a copy of the excellent PGCEdit (shareware) and load the compiled disc.
http://download.videohelp.com/r0lZ/pgcedit/index.html
Find the main timeline for the slideshow, and double click it. (see attached image)
The "chapters" will be listed, and we need to see these ticked as sequential playback, or seamless.
If there is no tick, add one between each track, save the disc & reburn with IMGBurn (freeware/Donationware)
For some reason, certain chipsets seem to create a gap when transitioning a chapter marker on a timeline with a single sequential audio stream when the chapter is incorrectly set to non seamless.
This may not be what is happening here, but I think it is worth a look.
Seamless markers.JPG 264.7 K
2. Re: Slide Show Audio Problem at Beginning of Show
jkb242 May 14, 2010 1:33 PM (in response to Neil Wilkes)Neil,
Thanks, I will look at what you suggested
suggested. If this stumped a pro like you, I don't feel all that bad--
just worn out but interested to learn from the experience.
There are three sequencies DL'ed from Premier in the Encore project,
then there is the slide show that was created in Encore. The entire
project is close to max size (4.6Gb) but I don't see the size as a
contributor to the problem since the show is second play behind the
menu--if the disk is burned in order of play (inside to outside) but
the play order may not always follow burn order, right?
I never saw the exmple attached you mentioned, but I am reading and
responding from my iTouch.
Thanks again!!
Sent from my iPod
