4 Replies Latest reply on Oct 19, 2010 10:07 PM by Boble5
    Read and import data from excel file
    Boble
      Hi guys, with indesign scripting can read and import data from an excel or csv file. I have tried the activexobject and it does not work
      var excel = new ActiveXObject("Excel.Application");
      var excel_file = excel.Workbooks.Open("D:\Delete\Indesign\positions.xls");
      var excel_sheet = excel_file.Worksheets("Sheet1");
      Is there a way? I want to be able to insert data from an excel file into specific textframes.
      Thanks for any help.
        • 1. Re: Read and import data from excel file
          Steven.. Level 3
          Is your question how to read the data in excel or how to place into inDesign
          • 2. Re: Read and import data from excel file
            Boble Level 1
            How to read it. Sort of treating it as a database  of some kind.
            So i could have an excel file on my hard drive then fill up textframes with values from the excel file.
            Pseudo code would be something like this
            Read excel file
            doc.textFrames.item(0).contents=Row1.Column1.From.Excel.File
            doc.textframes.item(1).contents=Row2.Colum1.From.Excel.File
            Obviously that's just imaginary syntax! But i hope it explains what i want to do.
            • 3. Re: Read and import data from excel file
              Steven.. Level 3
              I don't know if excel can be accessed via javascript, however using vbscript you would be able to take advantage of a robust com object model
              • 4. Re: Read and import data from excel file
                Boble5
                Trying to do this again, now in Visual Basic. This works perfectly.
                Set myInDesign = CreateObject("InDesign.Application")
                Set myDocument = myInDesign.ActiveDocument
                Set myPages = myDocument.Pages
                Set myExcel = CreateObject("Excel.Application")
                Set objWorkbook = myExcel.Workbooks.Open("C:\Downloads\links.xls")
                Set objSheet = myExcel.ActiveWorkbook.WorkSheets(1)
                value_one=objSheet.Cells(1,1).Value
                msgbox ( value_one )
                objWorkBook.close
                Amazing stuff. What a buzz
