1 Reply Latest reply on May 13, 2010 4:20 AM by TeotiGraphix
    @checked for an Array
    Nirmal Kumar Bhogadi Level 1
      Hello All,
      I have an issue regarding a checkbox.  I have a tree for which the children are dynamically created as  XMLList. For XMLList I am using AllOfficers[u].@checked = "0". Here AllOfficers is a XMLList type. "0" is to disable the checkbox.  I want the same functionality for an Array. I tried with selectedOfficerName[u].@checked = "1", where selectedOfficerName is an Array but found no luck. Can somebody help me in this respect.
      Thanks in advance,
        • 1. Re: @checked for an Array
          TeotiGraphix Level 3
          Are you saving an XML node in the Array index? If so I don't think bindable properties work since you have detached it from the actual XML list.
          You would need to create a class that had a Bindable property "checked", then you could bind to that property in the Array's index.
          Mike
