8 Replies Latest reply on Jul 7, 2006 12:44 PM by PackinDaMAC
    The value "115,223.39" cannot be converted to a number
    PackinDaMAC Level 1
      I have this value "115,223.39" in my database when it tries to pull this data i get this message.
      The value "115,223.39" cannot be converted to a number....Any help on this
        • 1. Re: The value "115,223.39" cannot be converted to a number
          Level 7
          It's not a number, it is a string, it has a comma in it.
          You will need to do something to remove the comma if you want it to be a
          number. A large hammer way to do this is with replace.
          #replace('115,223.60',',','','ALL')#
          Boy that is a bit confusing isn't it. Make sure you get all the quotes
          and commas matched up correctly.
          > get this message.
          > <cfset res.endingar = Replace(res.endingar, ",", "", "all")>
          > <cfchart format="jpg" chartheight="400" chartwidth="800">
          > <cfchartseries type="line" colorlist="008800,00cc00, 000088, 0000cc">
          > <cfloop query="res">
          > <cfchartdata item="#res.themonth#" value="#Int(res.endingar)#">
          > </cfloop>
          > </cfchartseries>
          > </cfchart>
          > </cfoutput>
          • 2. Re: The value &quot;115,223.39&quot; cannot be converted to a number
            Level 7
            Ok, actually looking at your code you are replacing comma's. You may
            need to add a val() function around that to force the conversion from
            string to number.
            >> this
            >> 0000cc">
            >> </cfloop>
            >> </cfchartseries>
            >> </cfchart>
            >> </cfoutput>
            • 4. Re: The value &quot;115,223.39&quot; cannot be converted to a number
              PackinDaMAC Level 1
              <cfset res.charges = Val(Round(Replace(res.charges, ",", "", "all")))>
              I still get the same error...that number is just a value it pulls from the sql server.....im lost
              • 5. Re: The value &quot;115,223.39&quot; cannot be converted to a   number
                Level 7
                Try putting the val before the round, since the round function would
                also be expecting a number.
                Are there any null values in the records returned by the query. These
                can cause this kind of problem since an "" [empty string] is not a
                number. Putting a val() around that will return a zero '0' for
                null|empty string values in the recordset.
                • 6. Re: The value &quot;115,223.39&quot; cannot be converted to a number
                  MikerRoo Level 1
                  "res" is a query. So that approach will not work unless the query contains exactly one row.
                  The BEST thing to do is to fix the data in your original query, like so:
                  <CFQUERY name="res" ... ...>
                  SELECT
                  themonth,
                  Replace (endingar, ",", "") AS endingar
                  </CFQUERY>
                  The above syntax works in many RDBMS. Tell us which RDMBS you are using if it doesn't work for you.
                  • 7. Re: The value &quot;115,223.39&quot; cannot be converted to a   number
                    Level 7
                    Actually since it is in a query loop it will work just fine to output
                    all the records in the set.
                    Test code that can be run if you have the CF sample databases installed.
                    <cfquery datasource="cfartgallery" name="test">
                    SELECT ARTISTID
                    FROM ARTISTS
                    </cfquery>
                    <cfoutput>
                    <cfloop query="test">
                    #test.artistid#<br/>
                    </cfloop>
                    </cfoutput>
                    > exactly one row.
                    > SELECT
                    > themonth,
                    > </CFQUERY>
                    • 8. Re: The value &quot;115,223.39&quot; cannot be converted to a number
                      PackinDaMAC Level 1
                      Thanks 4 the help guys but all i needed to do was add that replace statement inside my loop...It was not being converted beacause it was outside the loop...dang.....thanks 4 the help...thats the correct code snippet.....
