8 Replies Latest reply on May 14, 2010 7:04 AM by pebalsamo
    AVCHD in Premiere Pro CS 5 - exporting file type questions
    adamgreenwood
      Firstly, this is my first post on here, so apologies if I'm breaking any kind of etiquette. Also, I'm not a very technical person and would appreciate any comments or advice to be in layman's terms!
      So, I film and edit weddings as part of a small company. I've recently had my camera and editing system upgraded to a Sony NXcam and Premiere Pro CS5 and I'm having a little trouble getting used to the new file types and settings (previously used miniDV tapes in SD with a Canon XL2 in an older version of Premiere).
      My pc handles the AVCHD footage fine but the way that I edit means that I'll want to export a sequence of edited clips as one long clip, and then re-import it. For example, I'm editing the wedding ceremony from footage from two cameras - I'm going to edit the full version of the ceremony and then I'm also going to edit it down into a version that is a highlights montage in slo-motion to music. The way I do this is once I'm happy with the full version of the ceremony I'll export it and then re-import it so it's one long clip I can play with rather than two sets of footage chopped up on a sequence. So I can alter the speed of this new long clip, and then chop it up and stick in some dissolves to put together the montage. Then I use this montage in the middle of my final film, between the preparations and the reception. The full, edited version of the ceremony is used as an extra on the DVD.
      Previously this was fairly straight forward. I was always working with footage in 16:9 and could export it as an avi file, then re-import that avi file with no problems - presto; the exact same-looking footage as I was previously working with.
      Now I'm editing with avchd mts footage (1920x1080 - 25p - square pixels?). Naturally, if I export it as a 16:9 avi and re-import it, the aspect ratio and frame size is all wrong for the project sequence.
      I just want to know what the best file format and settings are to use to export footage that will match up.  There is no option that I can see to export edited footage as mts files. There is a long list of file types, most of which I don't recognise or know anything about and have never needed to use in the past.
      Sorry if this is a silly question, I've tried searching for "working with AVCHD in premiere pro cs5" in google and not been able to find anything that can help me on there, so I thought I'd try a forum like this.
      Cheers
      Adam
        • 1. Re: AVCHD in Premiere Pro CS 5 - exporting file type questions
          Harm Millaard Level 7
          Adam,
          Instead of exporting, importing and reencoding again with all the generation losses, you better look at nested sequences.
          Sequence 1: your long form movie. Prior to encoding, create a new sequence 2, and drag sequence 1 into it. Edit that for the short form version.
          You need to encode both sequences, but only have one generation loss.
          • 2. Re: AVCHD in Premiere Pro CS 5 - exporting file type questions
            pebalsamo Level 2
            Just as Harm says.
            That is exactly how i edit my montages from wedding services and receptions.  Just double click on the sequence in your project panel and it will open up in your source monitor.  Then just scrub through the footage and set an in point and then an out point and drop it in your timeline.  Scrub forward some more and set new in and out points adn drop the next clip in the timeline.  From the timeline you can do all your effects to the individual clips.
            FYI - I am using CS4, but I would assume that this would still work in CS5
            Phil
            • 3. Re: AVCHD in Premiere Pro CS 5 - exporting file type questions
              adamgreenwood Level 1
              Thanks for both your responses. I was aware that I could do it the way you've suggested, but I think it's more time consuming that way, possibly. I may resort to that, but if you could give me some tips on the different export settings/formats as well that'd be very helpful as well! At the moment I know avi is fairly reliable SD footage, WMV is good for uploading files to the net but beyond that I'm not too sure.
              • 4. Re: AVCHD in Premiere Pro CS 5 - exporting file type questions
                It will not be more time consuming, but it will give better quality in the same time.
                • 5. Re: AVCHD in Premiere Pro CS 5 - exporting file type questions
                  Well I guess it depends on the way that you work. Personally, it's always been quicker for me the way I said.
                  I would still find it very useful if you could give me some tips on the file types, if that's ok?
                  • 6. Re: AVCHD in Premiere Pro CS 5 - exporting file type questions
                    pebalsamo Level 2
                    I do not understand what you think would be more time consuming.  If you export a file then you have to wait for that to render and export, then bring it into Premiere and then edit it apart the same way that you could just by using your sequence (without exporting).  Plus as Harm mentions then it is the best quality possible.
                    I would strongly suggest that you try it and if you really do not like it check out the hd2sd tutorial on the following page.
                    http://bellunevideo.com/tutlist.php
                    In the 720p60 section Jeff talks about exporting an intermidiate format MPEG2 file that may work for what you are looking for.  Keep in mind though that this intermediate file is no longer necessary with updates to CS4 (and I am sure with CS5) when going from HD to SD.  Obviously you would have to tweek the settings to match your footage, but it should get you going...
                    If you do not mind explaning what part of the process that I use you think is more time consuming.  I would just like to see if you are miss understanding something.
                    Enjoy.
                    Phil
                    • 7. Re: AVCHD in Premiere Pro CS 5 - exporting file type questions
                      Thank you for the link to that video. I will give it a watch soon and hopefully it will be helpful.
                      With regard to the different methods of working and which is more time consuming, I really only meant that the way I worked was best for me because I could leave the PC rendering/exporting etc while I worked on something else, rather than adding effects etc to each individual file which would require me to be sat at my edit station for longer. Although it might take longer to get to the end result that way, I still have more time free to get on with other things which makes it a more time-efficient way to work.
                      Like I said before, it all depends on how you prefer to work - thanks for asking about it though!
                      • 8. Re: AVCHD in Premiere Pro CS 5 - exporting file type questions
                        pebalsamo Level 2
                        I think we may have a slight miscommunication.  This is the way that I interpreted your original post.
                        Lets say you shot the Smith/Jones wedding this past weekend.  You start a new project and have a Service Sequence and a Reception Sequence.  You finish editing both the service and reception and just a standard full length video.  Now you want to create a montage with clips from both the service and reception.  In this montage you will have different effects like Black and white, Slo Mo, blurs, etc.  So what you do is export the service and reception and then import those two files (or one long one) and then cut that apart and add your music and effects to make your montage.  Is that correct?
                        The way that I do it works the exact same way except that you skip the export part.
                        When I edit a wedding I generally have 4 sequences when I am finished.  I have a Pre Wedding montage, service, reception, and ending highlights.  The Pre Wedding montage is just made up of shots from before the service (bride and bridesmaids getting ready, shots of the venu, groom and groomsmen and so on).  Then I have a full edit of the service and a full edit of the reception.  After I am finished with those 3 sequences I start working on the ending highlight collage.  I make a new sequence for the collage then I go to my bin and drag the "Service Sequence" up into the preview monitor (I know in my previous post I said double click.  That does not work, because that just opens it up as a sequence.  Sorry about that).  In the preview monitor I scrub through the footage until I find a section that I want in the montage.  Then I set in and out points around that clip and drop it into my Montage timline, and what ever effects to it that I want, then move on to the next clip and do the same thing.  To me it seems that we have the same process except that you have to wait for the export (which is always going to give you a quality loss, how much of a loss depends on format and settings).
                        Please let me know if I have misread your process.
                        Phil
