6 Replies Latest reply on May 13, 2010 2:06 PM by TeotiGraphix
    Custom Spark Component + Skin Doesn't Display Properly in Flash Builder
    vmvmvmvmvm Level 1
      I'm creating a custom spark component that has a custom content area to be used in MXML much like a Panel's controlbar and content. I mimiced the Panel and PanelSkin implementation but it doesn't render properly in FlashBuilder, however it looks fine at run time. My custom group is called headerGroup. And I followed the controlBar implementation in Panel. My skin file should show the header at the top of the container. For debugging, I just renamed my headerGroup to contentGroup (defined in SkinnableContainer) and I can see this content at design time.
      What do I need to do extra to get my custom group to show up at design time? Below, I've pasted my componetn and its skin file.
      Console.as
      package
      import flash.utils.describeType;
      import mx.core.mx_internal;
      import mx.utils.BitFlagUtil;
      import spark.components.Button;
      import spark.components.Group;
      import spark.components.SkinnableContainer;
      import spark.components.supportClasses.SkinnableComponent;
      import spark.layouts.supportClasses.LayoutBase;
      use namespace mx_internal;
      public class Console extends SkinnableContainer
      protected const CONSOLE_HEADER:String = 'consoleHeader';
      protected static const HEADER_PROPERTY_FLAG:uint = 1 << 0;
      protected static const LAYOUT_PROPERTY_FLAG:uint = 1 << 1;
      protected static const VISIBLE_PROPERTY_FLAG:uint = 1 << 2;
      mx_internal static var createAccessibilityImplementation:Function;
      [SkinPart(required="false")]
      public var headerGroup:Group;
      mx_internal var headerGroupProperties:Object = { visible: true };
      [ArrayElementType("mx.core.IVisualElement")]
      public function get headerContent():Array
      if (headerGroup)
      return headerGroup.getMXMLContent();
      else
      return headerGroupProperties.headerContent;
      public function set headerContent(value:Array):void
      if (headerGroup)
      headerGroup.mxmlContent = value;
      headerGroupProperties = BitFlagUtil.update(headerGroupProperties as uint,
      HEADER_PROPERTY_FLAG, value != null);
      else
      headerGroupProperties.headerContent = value;
      invalidateSkinState();
      public function get headerLayout():LayoutBase
      return (headerGroup)
      ? headerGroup.layout
      : headerGroupProperties.layout;
      public function set headerLayout(value:LayoutBase):void
      if (headerGroup)
      headerGroup.layout = value;
      LAYOUT_PROPERTY_FLAG, true);
      else
      headerGroupProperties.layout = value;
      public function get headerVisible():Boolean
      ? headerGroup.visible
      : headerGroupProperties.visible;
      public function set headerVisible(value:Boolean):void
      if (headerGroup)
      headerGroup.visible = value;
      VISIBLE_PROPERTY_FLAG, value);
      else
      headerGroupProperties.visible = value;
      if (skin)
      skin.invalidateSize();
      *  @private
      override protected function initializeAccessibility():void
      if (VMConsole.createAccessibilityImplementation != null)
      VMConsole.createAccessibilityImplementation(this);
      override protected function partAdded(partName:String, instance:Object):void
      super.partAdded(partName, instance);
      if (instance == headerGroup)
      // copy proxied values from headerGroupProperties (if set) to headerGroup
      var newHeaderGroupProperties:uint = 0;
      if (headerGroupProperties.headerContent !== undefined)
      headerGroup.mxmlContent = headerGroupProperties.headerContent;
      newHeaderGroupProperties = BitFlagUtil.update(newHeaderGroupProperties,
      HEADER_PROPERTY_FLAG, true);
      if (headerGroupProperties.visible !== undefined)
      headerGroup.visible = headerGroupProperties.visible;
      VISIBLE_PROPERTY_FLAG, true);
      headerGroupProperties = newHeaderGroupProperties;
      override protected function partRemoved(partName:String, instance:Object):void
      super.partRemoved(partName, instance);
      override protected function getCurrentSkinState():String
      var state:String = enabled ? "normal" : "disabled";
      if (headerGroup)
      if (BitFlagUtil.isSet(headerGroupProperties as uint, HEADER_PROPERTY_FLAG) &&
      BitFlagUtil.isSet(headerGroupProperties as uint, VISIBLE_PROPERTY_FLAG))
      state += "WithHeader";
      else
      if (headerGroupProperties.headerContent &&
      headerGroupProperties.visible)
      return state;
      ConsoleSkin.mxml
      <s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:mx="library://ns.adobe.com/flex/mx">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Metadata>
      <![CDATA[
      * @copy spark.skins.spark.ApplicationSkin#hostComponent
      [HostComponent("Console")]
      </fx:Metadata>
      <s:states>
      <s:State name="normal" />
      <s:State name="disabled" />
      <s:State name="normalWithHeader" />
      <s:State name="disabledWithHeader" />
      </s:states>
      <s:Rect id="shadow" left="-1" right="-1" top="-1" bottom="-1" radiusX="2">
      <s:fill>
      <s:LinearGradient rotation="90">
      <s:GradientEntry color="0x000000"
      alpha="0.01" />
      alpha="0.07" />
      </s:LinearGradient>
      </s:fill>
      </s:Rect>
      <s:Rect id="fill" left="1" right="1" top="1" bottom="1" radiusX="2">
      <s:fill>
      <s:GradientEntry color="0xFFFFFF"
      alpha="0.85" />
      <s:GradientEntry color="0xD8D8D8"
      alpha="0.85" />
      </s:LinearGradient>
      </s:fill>
      </s:Rect>
      <s:Group id="headerGroup" width="100%" height="100%">
      <s:layout>
      <s:HorizontalLayout paddingLeft="10" paddingRight="10" paddingTop="7" paddingBottom="7" gap="10" />
      </s:layout>
      </s:Group>
      </s:SparkSkin>
