0 Replies Latest reply on Jul 9, 2006 2:51 PM by DBinCO
    CFDocument: works in dev but not prod?
    DBinCO
      We are using CFMX 7,0,2,142559 Standard on W2K3 servers. In our dev and qa environements, cfdocument works fine, but in production it does not, and produces the error below in the errror log.
      The code is all the same, the data is the same - I have sinked our dev and qa servers with the production data. I have even put out a test file in all environments containing the following:
      <cfdocument format="pdf">
      Dave's content
      </cfdocument>
      It Streams to the browser just fine in dev and qa, but in production the browser times out, and the error below is produced.
      Anyone else see this?
      Thanks in advance.
      "Error","jrpp-58","07/09/06","15:31:55","Corporate","The document has no pages. The specific sequence of files included or processed is: E:\sites\corp\docs\pressroom\press_releases\pr_in_pdf.html, line: 23 "
      java.io.IOException: The document has no pages.
      at com.lowagie.text.pdf.PdfPages.writePageTree(Unknown Source)
      at com.lowagie.text.pdf.PdfWriter.close(Unknown Source)
      at com.lowagie.text.pdf.PdfDocument.close(Unknown Source)
      at com.lowagie.text.Document.close(Unknown Source)
      at coldfusion.tagext.lang.DocumentTag.doAfterBody(DocumentTag.java:1225)
      at cfpr_in_pdf2ehtml894705829.runPage(E:\sites\corp\docs\pressroom\press_releases\pr_in_pdf. html:23)
      at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152)
      at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:349)
      at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
      at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:225)
      at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:51)
      at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
      at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:69)
      at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
      at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
      at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
      at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
      at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:115)
      at coldfusion.CfmServlet.service(CfmServlet.java:107)
      at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78)
      at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
      at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
      at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:257)
      at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541)
      at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:204)
      at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:318)
      at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:426)
      at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:264)
      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
