3 Replies Latest reply on May 14, 2010 7:38 AM by ska-man
    Problem with memory allocation of arraycollection by AddItem
    ska-man
      I have a strange problem with the method AddItem.
      I made a new item with this code:
      for (var u:int = 0; u<41; u++){
            pagina=new PageToSave();
            project.addPage(pagina as PageToSave);
      project is an istance of projectblueprint class:
      package marcoDoItBetter.utils
          import mx.collections.ArrayCollection;
          public class ProjectBlueprint
              private var _pages:ArrayCollection;
              public function addPage(page:PageToSave):void
                  this._pages.addItem(page);
      PageToSave is a class that extends object.
      When we create the item using programmatically the addPages method (so using addItem in the _pages arraycollection) we have this result using the expression inspector in the debug mode.
      This is on the debugger output:
      pageList = mx.collections.ArrayCollection (@105cf341)
          [inherited] =
          [0] = marcoDoItBetter.utils.PageToSave (@113cb461)
          [1] = marcoDoItBetter.utils.PageToSave (@113cb401)
          [2] = marcoDoItBetter.utils.PageToSave (@113cb3a1)
          [3] = marcoDoItBetter.utils.PageToSave (@113cb341)
          [4] = marcoDoItBetter.utils.PageToSave (@113cb2e1)
          [5] = marcoDoItBetter.utils.PageToSave (@113cb281)<----------
          [6] = marcoDoItBetter.utils.PageToSave (@113cb221)
          [7] = marcoDoItBetter.utils.PageToSave (@113cb1c1)
          [8] = marcoDoItBetter.utils.PageToSave (@113cb161)
          [9] = marcoDoItBetter.utils.PageToSave (@113cb101)
          [10] = marcoDoItBetter.utils.PageToSave (@113cb0a1)
          [11] = marcoDoItBetter.utils.PageToSave (@113cb041)
          [12] = marcoDoItBetter.utils.PageToSave (@1140dfa1)
          [13] = marcoDoItBetter.utils.PageToSave (@1140df41)
          [14] = marcoDoItBetter.utils.PageToSave (@1140dee1)
          [15] = marcoDoItBetter.utils.PageToSave (@1140de81)
          [16] = marcoDoItBetter.utils.PageToSave (@1140de21)
          [17] = marcoDoItBetter.utils.PageToSave (@1140ddc1)
          [18] = marcoDoItBetter.utils.PageToSave (@1140dd61)
          [19] = marcoDoItBetter.utils.PageToSave (@1140dd01)
          [20] = marcoDoItBetter.utils.PageToSave (@1140dca1)
          [21] = marcoDoItBetter.utils.PageToSave (@1140dc41)
          [22] = marcoDoItBetter.utils.PageToSave (@113cb281)<------------
          [23] = marcoDoItBetter.utils.PageToSave (@1140db81)
          [24] = marcoDoItBetter.utils.PageToSave (@1140db21)
          [25] = marcoDoItBetter.utils.PageToSave (@1140dac1)
          [26] = marcoDoItBetter.utils.PageToSave (@1140da61)
          [27] = marcoDoItBetter.utils.PageToSave (@1140da01)
          [28] = marcoDoItBetter.utils.PageToSave (@1140d9a1)
          [29] = marcoDoItBetter.utils.PageToSave (@1140d941)
          [30] = marcoDoItBetter.utils.PageToSave (@1140d8e1)
          [31] = marcoDoItBetter.utils.PageToSave (@1140d881)
          [32] = marcoDoItBetter.utils.PageToSave (@1140d821)
          [33] = marcoDoItBetter.utils.PageToSave (@1140d7c1)
          [34] = marcoDoItBetter.utils.PageToSave (@1140d761)
          [35] = marcoDoItBetter.utils.PageToSave (@1140d701)
          [36] = marcoDoItBetter.utils.PageToSave (@1140d6a1)
          [37] = marcoDoItBetter.utils.PageToSave (@1140d641)
          [38] = marcoDoItBetter.utils.PageToSave (@1140d221)
          [39] = marcoDoItBetter.utils.PageToSave (@1140d5e1)
          [40] = marcoDoItBetter.utils.PageToSave (@1140d461)
          source = Array (@1140c9a9)
      as you can see the [5] and the [22] PageToSave instances of the class has the same address referencing(or internal flex id.
      I don't know the exact name of it). It occurs in a totally random manner.
      sometimes all goes well, sometimes there are more than one duplicate with random address referencing match.
      I don't want duplicate instances but I want independent instances.
      I tried changing addItem with
           this._pages.addItemAt(page,0);
      Same result.
      I also tried pagina=null before the new statement but same result
            pagina = null;
      is a garbage collector issues?
      how we can fix it?
      Thank you
