1 Reply Latest reply on May 18, 2010 6:56 AM by gauravontop
    Microphone activity level
    gauravontop Level 1
      I have to display the activity level of the microphone (sound being detected by microphone) in a flex project. I started with using a progress bar and attached a ChangeWatcher to microphone.activityLevel but found out that ChangeWatcher cannot watch "activityLevel".
      How should I go about it because progress bar also does not seem to be a right component as multi colored display is required. I cannot monitor changes in the sound level of the microphone. Any help would be appreciated. Please check the attached image.
        • 1. Re: Microphone activity level
          gauravontop Level 1
          Since no one ever responded I will answer this as to how I eventually did it. I used an image and the microphone's activityLevel attribute to show the the real time sound input to the microphone. Since this activityLevel is not bindable I had to use a timer.
          Also do remember to get a valid value of activityLevel apart from  calling
          microphone = Microphone.getMicrophone();
          also use
          microphone.setLoopBack(true);
          microphone.setUseEchoSuppression(true);
          Otherwise the activityLevel value is -1  The second point is not mentioned in flex docs
