0 Replies Latest reply on May 14, 2010 5:53 AM by athiroy
    Compile multiple mxml file at same time
    athiroy Level 1
      hi
      i am working in flex with java.
      i am using more one flex file in my flex project.
      when i execute the project the ant compiled .mxml file only executed.
      the other .mxml files are not executed.
      i have use the destination id  same of two mxml files.
      the ant target is
      <target name="appcompile" depends="install">
        <mxmlc file="${flexsrc.home}/UserRegistration.mxml" context-root="/Reg" keep-generated-actionscript="true" services="${web.home}/WEB-INF/flex/services-config.xml" output="${catalina.home}/webapps/${app.name}/UserRegistration.swf">
         <compiler.library-path dir="${FLEX_HOME}/frameworks" append="true">
          <include name="${web.home}/WEB-INF/lib/" />
          <include name="${flexsrc.home}/example/" />
         </compiler.library-path>
         <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml" />
         <source-path path-element="${FLEX_HOME}/frameworks" />
        </mxmlc>
      </target>
      <target name="createHtmlWrapper" depends="appcompile">
        <html-wrapper application="${APP_ROOT}/UserRegistration.mxml" height="1000" width="1000"  output="${catalina.home}/webapps/${app.name}" swf="UserRegistration" />
      </target>
      the destination id is camp;
      the error is
      MessagingError message='Destination 'camp' either does not exist or the destination has no channels defined (and the application does not define any default channels.)']
      anyone can help me
      regards
      athi
