I installed Adobe Flash Builder 4 as a plugin for Eclipse for J2EE developers (galileo Eclipse Build id: 20100218-1602). The code highlighting doesn't work for mxml files, and the Outline view doesn't work for either MXML or AS files.
When I start it stand-alone, it works fine...
Can somebody help me out as to how I can get this going to work as a plugin with eclipse galileo?
Just a reminder, you need to be in Flash Perspective in order to use all Flash Builder features. Not sure if this answers your questions though.
Thanks.
Yes. I should have mentioned, that I am using Flash Perspective as well.
I am also seeing this same issue. We have our projects structured in a parent->subproject setup in eclipse:
-Parent Project
-- Sub1
--Sub2
When this structure is created inside the IDE everything works fine. We use subversion for version management and when the parent project is checked out of subversion and the sub projects are setup as flex projects none of the outlining and code completion works.
I don't even have project complexity you are talking about. Just one project -- that's all. I think Flash Builder doesn't play well with galileo eclipse.
So if somebody out there in the Adobeland can help a brother out with that, it would be just superawesome!
I believe that Galileo was a requirement for FB4. We are also on Mac OS X. We are also using the J2EE download of Galileo.
I think you are right.
Galileo being a requirement is kind weird because when I start FB4 using the "start as standalone" shortcut, it actually fires up an isntance of Ganymede (or however you spell that thing)... Ugh.
BTW, my problem is on windows.
Are you also using subversion?
Are you experiencing this problem on an existing project that you are taking from Flex Builder 3 to Flash Builder 4?
Is your code completion borken too?
If you create a new Flex Project using the new project wizard does everything work?
We purchased 10 Flash Builder 4 Pro licenses and Adobe has been absolutely no help with this issue. They just told us there must be a problem with your workspace meta-data, sorry. We have created new, clean workspaces and the problem persists.
Yes. I am using SVN, but have not integrated it into eclipse
No. This is a FB4 project
Yes. Code completion is broken.
Haven't tried it.
Adobe = no help? That's aggravating.
Can you please dump the contents of your log file? (It should be present in workspacedir/.metadata/.log)
Cheers,
Anirudh
!SESSION 2010-05-12 13:17:26.682 -----------------------------------------------
eclipse.buildId=java.version=1.6.0_17java.vendor=Apple Inc.BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_USFramework arguments: -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -keyring /Users/jeff/.eclipse_keyring -showlocationCommand-line arguments: -os macosx -ws carbon -arch x86 -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -data /Users/jeff/workspaces/crengland_flex3 -product org.eclipse.epp.package.jee.product -keyring /Users/jeff/.eclipse_keyring -showlocation!ENTRY org.eclipse.equinox.p2.repository 4 0 2010-05-12 13:17:27.369
Here is mine. It is alos very long:
!SESSION 2010-05-14 11:35:27.266 -----------------------------------------------
eclipse.buildId=M20090211-1700
java.version=1.6.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.core.filebuffers 4 0 2010-05-14 11:35:53.062
!MESSAGE The content type with id "com.adobe.flexbuilder.project.content-type-mxml" specified in the extension point does not exist.
!MESSAGE The content type with id "com.adobe.flexbuilder.project.content-type-fxg" specified in the extension point does not exist.
!SESSION 2010-05-14 11:36:57.812 -----------------------------------------------
!ENTRY org.eclipse.core.filebuffers 4 0 2010-05-14 11:37:58.233
!ENTRY org.eclipse.core.filebuffers 4 0 2010-05-14 11:37:58.248
!ENTRY org.eclipse.jface 2 0 2010-05-14 11:38:25.951
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2010-05-14 11:38:25.951
!MESSAGE A conflict occurred for CTRL+G:
Binding(CTRL+G,
ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.workspace,Find All Declarations In Workspace,
Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true),
LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@f02243)),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
com.adobe.flexide.editorcore.flexEditorScope,,,system)
Binding(CTRL+G,
,,true),null),
com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system)
Binding(CTRL+G,
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.declarations.in.workspace,Declaration in Workspace,
Search for declarations of the selected element in the workspace,
Category(org.eclipse.search.ui.category.search,Search,Search command category,true),
,,true),null),
org.eclipse.ui.contexts.window,,,system)
!MESSAGE A conflict occurred for CTRL+SHIFT+G:
Binding(CTRL+SHIFT+G,
ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.workspace,Find All References In Workspace,
LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@1598845)),
,,true),null),
,,true),null),
ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.references.in.workspace,References in Workspace,
Search for references to the selected element in the workspace,
,,true),null),
!ENTRY com.adobe.flexbuilder.project 4 43 2010-05-14 11:38:38.498
!MESSAGE Bad root tag or version in parse design description file design.xml from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flexunit\flexunitUIListener\4.0-rc-1\flexunitUIListener-4.0-rc-1.swc
!STACK 0
java.lang.Exception
at com.adobe.flexbuilder.project.internal.FlexProjectCore.createErrorStatus(FlexProjectCore.java:972)
at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:66)
at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:50)
at com.adobe.flexide.designitems.types.DesignExtensions.buildTree(DesignExtensions.java:86)
at com.adobe.flexide.designitems.types.DesignExtensions.<init>(DesignExtensions.java:65)
at com.adobe.flexide.designitems.types.DesignTypeRegistry.<init>(DesignTypeRegistry.java:50)
at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.<init>(MXMLDesignView4Controller.java:175)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignViewFactory.createController(MXMLDesignViewFactory.java:42)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.initializeDesignView(MXMLDesignEditor.java:1578)
at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.setFocus(MXMLDesignEditor.java:1736)
at org.eclipse.ui.part.MultiPageEditorPart.setFocus(MultiPageEditorPart.java:1016)
at org.eclipse.ui.part.MultiPageEditorPart.setFocus(MultiPageEditorPart.java:998)
at org.eclipse.ui.part.MultiPageEditorPart.pageChange(MultiPageEditorPart.java:738)
at com.adobe.flexbuilder.editorcore.editor.CodeAndDesignEditor.pageChange(CodeAndDesignEditor.java:546)
at com.adobe.flexbuilder.mxml.editor.MXMLEditor.pageChange(MXMLEditor.java:479)
at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:973)
at com.adobe.flexbuilder.editorcore.editor.CodeAndDesignEditor.setActivePage(CodeAndDesignEditor.java:683)
at com.adobe.flexbuilder.mxml.editor.MXMLEditor.setActivePage(MXMLEditor.java:544)
at com.adobe.flexbuilder.editorcore.editor.CodeAndDesignEditor$1.clicked(CodeAndDesignEditor.java:454)
at com.adobe.flexide.editorcore.ui.controls.ButtonBar.clicked(ButtonBar.java:289)
at com.adobe.flexide.editorcore.ui.controls.AbstractButton.sendClickEvent(AbstractButton.java:41)
at com.adobe.flexide.editorcore.ui.controls.ToggleButton.handleChange(ToggleButton.java:79)
at com.adobe.flexide.editorcore.ui.controls.ToggleButton.mouseDown(ToggleButton.java:66)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:179)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2200)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:490)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:38:41.935
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\automation\4.0.0.14159-freesdk\automation-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:38:43.951
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\automation_agent\4.0.0.14159-freesdk\automation_agent-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:38:45.998
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\automation_air\4.0.0.14159-freesdk\automation_air-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:38:48.029
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\automation_dmv\4.0.0.14159-freesdk\automation_dmv-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:38:50.123
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\automation_flashflexkit\4.0.0.14159-freesdk\automation_flashflexkit-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:38:52.169
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\automation_spark\4.0.0.14159-freesdk\automation_spark-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:38:54.201
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\qtp\4.0.0.14159-freesdk\qtp-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:38:56.248
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\datavisualization\4.0.0.14159-freesdk\datavisualization-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:38:58.279
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\flash-integration\4.0.0.14159-freesdk\flash-integration-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:00.326
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\flex\4.0.0.14159-freesdk\flex-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:02.497
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\framework\4.0.0.14159-freesdk\framework-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:04.529
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\osmf\4.0.0.14159-freesdk\osmf-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:06.591
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\spark\4.0.0.14159-freesdk\spark-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:08.622
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\sparkskins\4.0.0.14159-freesdk\sparkskins-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:10.654
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\textLayout\4.0.0.14159-freesdk\textLayout-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:12.700
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\utilities\4.0.0.14159-freesdk\utilities-4.0.0.14159-freesdk.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:14.747
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flexunit\flexunit\4.0-rc-1\flexunit-4.0-rc-1.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:16.779
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flexunit\flexunitUIListener\4.0-rc-1\flexunitUIListener-4.0-rc-1.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:18.872
!MESSAGE Design view: Failed to load fonts.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flexunit\flexunitUIListener\4.0-rc-1\flexunitUIListener-4.0-rc-1.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:20.903
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\anywebcam\mock\mock-as3\0.0.14\mock-as3-0.0.14.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:22.950
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\googlecode\sfapi\0.2.6\sfapi-0.2.6.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:24.997
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\automation\4.0.0.14159-freesdk\automation-4.0.0.14159-freesdk-en_US.rb.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:27.028
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\osmf\4.0.0.14159-freesdk\osmf-4.0.0.14159-freesdk-en_US.rb.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:29.075
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\qtp_air\4.0.0.14159-freesdk\qtp_air-4.0.0.14159-freesdk-en_US.rb.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:31.122
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\spark\4.0.0.14159-freesdk\spark-4.0.0.14159-freesdk-en_US.rb.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:33.153
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\textLayout\4.0.0.14159-freesdk\textLayout-4.0.0.14159-freesdk-en_US.rb.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:35.200
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\flash-integration\4.0.0.14159-freesdk\flash-integration-4.0.0.14159-freesdk-en_US.rb.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:37.247
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\rpc\4.0.0.14159-freesdk\rpc-4.0.0.14159-freesdk-en_US.rb.swc, reason=DesignAssetLoader.CompleteTimeout
!ENTRY com.adobe.flexide.designitems 4 1 2010-05-14 11:39:39.278
!MESSAGE Design view: Failed to load library.swf from C:\Documents and Settings\mrutman\.m2\repository\com\adobe\flex\framework\datavisualization\4.0.0.14159-freesdk\datavisualization-4.0.0.14159-freesdk-en_US.rb.swc, reason=DesignAssetLoader.CompleteTimeout
I just downloaded and tried the stand-alone FB4. My project checked out of SVN also does not work in the stand-alone FB4. Here is the log from that.
!SESSION 2010-05-17 08:06:52.169 -----------------------------------------------
eclipse.buildId=unknown
Framework arguments: -keyring /Users/jeff/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws carbon -arch x86 -keyring /Users/jeff/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.equinox.ds 4 0 2010-05-17 08:06:52.772
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.equinox.internal.util.event; version="1.0.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1313)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1297)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:309)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:370)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1068)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:557)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:464)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:248)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:445)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 08:07:58.516
!MESSAGE p2:flexPlugin=/Applications/Adobe Flash Builder 4/plugins/com.adobe.flexbuilder.flex_4.0.0.272416/
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 08:07:58.583
!MESSAGE p2:root=/Applications/Adobe Flash Builder 4/
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 08:07:58.584
!MESSAGE p2: testWriteToFile /Applications/Adobe Flash Builder 4/configuration/permission-check.txt
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 08:07:58.585
!MESSAGE p2: test file writable
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 10:39:57.509
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 10:39:57.511
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 10:39:57.550
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-05-17 10:42:01.761
!MESSAGE Operation details
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-05-17 10:42:01.761
!MESSAGE Cannot complete the install because one or more required items could not be found.
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-05-17 10:42:01.761
!MESSAGE Software being installed: Subversive SVN Integration for the Mylyn Project (Optional) (Incubation) 0.7.9.I20100512-1900 (org.eclipse.team.svn.mylyn.feature.group 0.7.9.I20100512-1900)
!MESSAGE Missing requirement: Subversive SVN Integration for the Mylyn Project (Optional) (Incubation) 0.7.9.I20100512-1900 (org.eclipse.team.svn.mylyn.feature.group 0.7.9.I20100512-1900) requires 'org.eclipse.mylyn_feature.feature.group [3.0.0,4.0.0)' but it could not be found
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-05-17 10:42:01.762
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-05-17 10:42:01.762
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-05-17 10:42:01.762
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-05-17 10:42:01.766
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-05-17 10:42:01.766
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-05-17 10:42:01.767
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-05-17 10:42:01.774
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-05-17 10:42:01.774
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-05-17 10:42:01.774
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-05-17 10:44:07.716
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-05-17 10:44:07.717
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-05-17 10:44:07.717
!MESSAGE Software being installed: Subversive Revision Graph (Optional) (Incubation) 0.7.9.I20100512-1900 (org.eclipse.team.svn.revision.graph.feature.group 0.7.9.I20100512-1900)
!MESSAGE Missing requirement: Subversive Revision Graph (Optional) (Incubation) 0.7.9.I20100512-1900 (org.eclipse.team.svn.revision.graph.feature.group 0.7.9.I20100512-1900) requires 'org.eclipse.gef.feature.group [3.4.0,4.0.0)' but it could not be found
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-05-17 10:44:07.720
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-05-17 10:44:07.720
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-05-17 10:44:07.720
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 10:48:01.360
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 10:48:01.361
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 10:48:01.399
!ENTRY com.adobe.flexbuilder.standalone 4 1 2010-05-17 10:48:01.400
!ENTRY org.eclipse.equinox.p2.repository 2 0 2010-05-17 10:54:50.318
!MESSAGE Connection to http://mirror.cc.vt.edu/pub/eclipse/releases/galileo/201002260900/aggregate/plugins/org.eclipse.wst.server.core_1.1.102.v20100123.jar.pack.gz failed on Connection refused. Retry attempt 0 started
!STACK 0
java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:432)
at java.net.Socket.connect(Socket.java:525)
at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65)
at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361)
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1017)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:610)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:808)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:506)
at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98)
at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:317)
at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:263)
at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71)
at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:468)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:451)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:518)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:200)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:175)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:159)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.perform(MirrorRequest.java:95)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:507)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.DownloadJob.run(DownloadJob.java:64)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!ENTRY org.eclipse.equinox.p2.repository 2 0 2010-05-17 10:54:56.046
!MESSAGE Connection to http://mirror.cc.vt.edu/pub/eclipse/releases/galileo/201002260900/aggregate/plugins/org.eclipse.wst.server.ui_1.1.103.v20100123.jar.pack.gz failed on Connection refused. Retry attempt 0 started
!STACK 0
!SESSION 2010-05-17 11:19:00.081 -----------------------------------------------
!ENTRY com.adobe.flexbuilder.project 4 43 2010-05-17 12:42:28.320
!MESSAGE Error while retrieving predefined variables
!STACK 0
java.lang.NullPointerException
at com.adobe.flexbuilder.mxmlmodel.NamespaceHelper.getXMLNamesForClass(NamespaceHelper.java:213)
at com.adobe.flexbuilder.mxmlmodel.NamespaceHelper.getTagForClass(NamespaceHelper.java:169)
at com.adobe.flexide.mxml.core.filetemplates.MXMLFileTemplatesProvider.getPrefixForClass(MXMLFileTemplatesProvider.java:312)
at com.adobe.flexide.mxml.core.filetemplates.MXMLFileTemplatesProvider.getPreDefinedVariablesWithValues(MXMLFileTemplatesProvider.java:256)
at com.adobe.flexide.editorcore.filetemplates.AbstractFileTemplatesProvider.resolveTemplate(AbstractFileTemplatesProvider.java:184)
at com.adobe.flexide.editorcore.filetemplates.FileTemplatesManager.getFileContentForNewProject(FileTemplatesManager.java:267)
at com.adobe.flexide.editorcore.filetemplates.FileTemplateResolver.resolveTemplateForNewProject(FileTemplateResolver.java:50)
at com.adobe.flexbuilder.project.FlexProjectManager.getFileTemplateContentForNewProject(FlexProjectManager.java:1220)
at com.adobe.flexbuilder.project.internal.FlexProject.getDefaultApplicationContents(FlexProject.java:319)
at com.adobe.flexbuilder.project.actionscript.internal.ActionScriptProject.createMainApplication(ActionScriptProject.java:396)
at com.adobe.flexbuilder.project.actionscript.internal.ActionScriptProject.createMainApplication(ActionScriptProject.java:361)
at com.adobe.flexbuilder.project.ui.wizards.AbstractActionScriptProjectWizard$3.execute(AbstractActionScriptProjectWizard.java:364)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1800)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:944)
at com.adobe.flexbuilder.project.ui.wizards.AbstractActionScriptProjectWizard.doCreateMainApplication(AbstractActionScriptProjectWizard.java:370)
at com.adobe.flexbuilder.project.ui.wizards.AbstractActionScriptProjectWizard.performFinish(AbstractActionScriptProjectWizard.java:308)
at com.adobe.flexbuilder.project.ui.wizards.AbstractFlexProjectWizard.access$1(AbstractFlexProjectWizard.java:1)
at com.adobe.flexbuilder.project.ui.wizards.AbstractFlexProjectWizard$FlexStrategy.perFormFinish(AbstractFlexProjectWizard.java:794)
at com.adobe.flexbuilder.project.ui.wizards.AbstractFlexProjectWizard.performFinish(AbstractFlexProjectWizard.java:567)
at com.adobe.flexbuilder.project.ui.wizards.FlexApolloProjectWizard.performFinish(FlexApolloProjectWizard.java:94)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:752)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1598)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1622)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1607)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1396)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3484)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3068)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:135)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java:109)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
!ENTRY org.eclipse.jface 2 0 2010-05-17 12:42:43.490
!SUBENTRY 1 org.eclipse.jface 2 0 2010-05-17 12:42:43.490
!MESSAGE A conflict occurred for COMMAND+G:
Binding(COMMAND+G,
LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@1ba0e0e)),
,,true),null),
Binding(COMMAND+G,
,,true),null),
!MESSAGE A conflict occurred for COMMAND+SHIFT+G:
Binding(COMMAND+SHIFT+G,
LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@1f0d2a3)),
,,true),null),
,,true),null),
Hi Jeffrey,
Looks like Subclipse is interfering with Flash Builder's template infrastructure in some weird way.
I've logged a bug: https://bugs.adobe.com/jira/browse/FB-26904 so that this can be investigated further.
Meanwhile, could you please try checking out the project via command line or another svn tool and then importing it in Flash Builder (with Subclipse installed) to see if it works? (If it works, please update the bug with the details).
Anirudh Sasikumar,
Flash Builder Engineering
I'm guessing you installed FB onto 3.4, then upgraded to 3.5 (or copied the plugins from 3.4 onto a 3.5 eclipse).
To be clear: Flash Builder supports Eclipse 3.5. But not the upgrade from 3.4 or (copy) scenario.
The core problem is that a jar named com.adobe.flexbuilder.project.e35_xxx.jar is missing in your case. The installer copies this jar out when it detects the host eclipse version as 3.5.
You need to reinstall Flash Builder onto Eclipse 3.5 or manually copy the jar into your plugins directory (this JAR is present in the standalone version which is 3.5)
Anirudh
Your guess is incorrect. I installed a fresh galileo.
I will try to copy the FB jar manually and see if this helps out.
Thank you so much for looking into this!!!
Checking out the project using an external SVN client worked. I updated the bug.
Umm. Where do I put com.adobe.flexbuilder.project.e35_xxx.jar ? plugins? features?
plugins
Hrm.
It didn't work.
What does your log say now?
P.S: It might be better if you re-install Flash Builder onto a clean Eclipse 3.5 installation.
Logs are below.
As I mentioned before, I did install on top of a clean galileo installation to begin with.
Binding(CTRL+G,
,,true),null),
Binding(CTRL+G,
,,true),null),
Binding(CTRL+G,
,,true),null),
,,true),null),
,,true),null),
,,true),null),
!STACK 0
java.lang.Exception
From eclipse.buildId, looks like you have Ganymede (3.4) rather than Galileo (3.5)?
On Galileo, this is how you can confirm if the project plugin loaded:
Go to Help -> Product Details -> Installation details -> Plugins and look for the plugin id com.adobe.flexbuilder.project.e35.
The plugin is there... The installation is galileo, and I am confused as to why the .log file thinks it is ganymede. To make things easier, I took a screenshot. Here it is. See annotations on it. I hope it helps:
This seems really strange. e35 has indeed been loaded.
Can you give me a list of plugins other than Flash Builder that you have installed?
Also, this may be time consuming to try out, can you try Flash Builder on a Java Developer version of Eclipse (and not the JEE)?
