4 Replies Latest reply on Jun 2, 2010 3:11 AM by David_F57
    How to align label text to the left in Spark Button (no "textAlign" style)?
    JabbyPandaUA Level 3
      Hi all,
      "textAlign" style is excluded for Spark Button, and probably for a good reason.
      [Exclude(name="textAlign", kind="style")]
        If I want to align Spark Button text label to the left, should I create custom skin to accomplish that?
      Something e.g:
      <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:mx="library://ns.adobe.com/flex/mx"
              minWidth="21" minHeight="21"
              alpha.disabled="0.5">
      <s:Label
              id="labelDisplay"
              textAlign="left"
              left="2" right="2" top="2" bottom="2"/>
      </s:Skin>
        • 1. Re: How to align label text to the left in Spark Button (no "textAlign" style)?
          I think, the answer is YES, one should create a custom skin to align label text for Spark Button accordingly to the reasoning provided at
          textAlign in PI doesn't do anything for s:Button
          https://bugs.adobe.com/jira/browse/SDK-24101
          • 2. Re: How to align label text to the left in Spark Button (no "textAlign" style)?
            David_F57 Level 5
            hi,
            if you only have a couple of buttons you can be lazy and in the button declaration and do this, or you create a skin, or you create an extended button class so that you can set the style at the begining of the app.
            <s:Button id="btn_login" width="150" label="Login" creationComplete="btn_login.labelDisplay.setStyle('textAlign','left')"/>
            David.
            [updated - typo]
            • 3. Re: How to align label text to the left in Spark Button (no "textAlign" style)?
                  Right, I though about this approach vith setStyle too, but this is not that convenient.
                  I looked into source code and find out that spark.components.Button class adds to the spark.components.supportClasses.ButtonBase only one public property "emphasized".
                Because I do not need this property in my project, I've extended my custom LinkButton component from ButtonBase to allow setting "textAlign" style in MXML for this component.
              import spark.components.supportClasses.ButtonBase;
              public class LinkButton extends ButtonBase {
                 Also,  inside custom Skin from my Button component I do not set explicitly "textAlign" style value to the button label, I let button label to inherit style value specified in MXML for the style textAlign of my ListButton component.
                  <fx:Metadata>
                      [HostComponent("component.LinkButton")]
                  </fx:Metadata>
              <s:Label
                      id="labelDisplay"
                      textDecoration="underline"
                      maxDisplayedLines="1"
                      verticalAlign="middle"
                      color="{getStyle('color')}"
                      color.over="{getStyle('textRollOverColor')}"
                      color.down="{getStyle('textSelectedColor')}"
                      left="10" right="10" top="2" bottom="2"/>
              </s:Skin>
              • 4. Re: How to align label text to the left in Spark Button (no "textAlign" style)?
                David_F57 Level 5
                hi,
                The extended component is by far the better way to go, and with a property in the extended component you can then bind to it in the skin so if you have
                [Bindable] public var textalign:string = "middle";
                then in the skin
                textAlign={hostcomponent.textalign}
                so now in the source/ mxml
                <comp:CustButton id="mybtn" textalign="left"/>
                David.
