3 Replies Latest reply on May 21, 2010 2:51 PM by flexchief
    Air to Air LocalConnection error
    flexchief Level 1
      I am unable to send and receive messages using local connection in air 1.5 but the exact same code works fine when run as a Flex app in the browser. Can someone please tell me where I am going wrong?
      Here is my code:
      Air App 1
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" initialize="initConn()">
          <mx:Script>
              <![CDATA[
              import flash.net.LocalConnection;
              private var conn:LocalConnection;
              private function initConn():void
                  btnSend.addEventListener(MouseEvent.CLICK, sendMessage);
                  conn = new LocalConnection();
                  conn.addEventListener(StatusEvent.STATUS, onStatus);
              private function sendMessage(event:MouseEvent):void
                  conn.send("taskConnection", "localconnectionHandler", inputTask.text);
              private function onStatus(event:StatusEvent):void
                  switch (event.level)
                      case "status":
                          labelStatus.text = "LocalConnection.send() succeeded";
                          break;
                      case "error":
                          labelStatus.text = "LocalConnection.send() failed";
                          break;
          </mx:Script>
          <mx:Panel horizontalCenter="0" verticalCenter="0">
              <mx:Form width="100%" height="100%" horizontalCenter="0" verticalCenter="0">
                  <mx:FormItem label="Enter Task">
                      <mx:TextInput id="inputTask"/>
                  </mx:FormItem>
                  <mx:FormItem label="Send Task ">
                      <mx:Button id="btnSend" label="Send"/>
                  </mx:FormItem>
                  <mx:ControlBar>
                      <mx:Label id="labelStatus" text=""/>
                  </mx:ControlBar>
              </mx:Form>
          </mx:Panel>
      </mx:WindowedApplication>
      Air App 2
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" initialize="InitConn()">
              <mx:Script>
              <![CDATA[
                  private function InitConn():void
                      conn.client = this;
                      try
                          conn.connect("taskConnection");
                      catch (error:ArgumentError)
                          trace("Can't connect.");
                  public function localconnectionHandler(msg:String):void
                      textareaTasks.text= textareaTasks.text + msg + "\n";
                  private function clearTasks(event:MouseEvent):void
                      textareaTasks.text="";
          </mx:Script>
              verticalCenter="0.5"
              verticalGap="15"
              paddingLeft="20" paddingRight="20" paddingBottom="20" paddingTop="20"
              height="300" width="500">
              <mx:Label text="Your tasks are..."/>
              <mx:TextArea id="textareaTasks"
                  top="20" left="20" right="20" bottom="20"
                  width="100%" height="100%"/>
              <mx:HBox>
                  <mx:Button id="btnClearTasks" click="clearTasks(event)" label="Clear Tasks"/>
              </mx:HBox>
          </mx:Panel>
        • 1. Re: Air to Air LocalConnection error
          Catalin Anastasoaie Adobe Employee
          The communication between the two air applications is not working because they are in different domains. In order to communicate you must explicitly tell your applications which domains are allowed to communicate with. For this you will have to make the following adjustments to your code:
          This code assumes that your apps are named LocalConnAir1 and LocalConnAir2
          For app1 you have to modify the sendMessage() function and tell it explicitly to send the the message to the connection named taskConnection from   the app#LocalConnAir1 domain:
                      conn.send("app#LocalConnAir2:taskConnection", "localconnectionHandler", inputTask.text);
          For app2 you have to modify the initConn() function and incoming messages from the app#LocalConnAir1 domain:
                          Alert.show(conn.domain);
                          conn.allowDomain("app#LocalConnAir1");
                          conn.client = this;
                          try
          Best Regards,
          -Catalin
          • 2. Re: Air to Air LocalConnection error
            flexchief Level 1
            Brilliant! That works perfectly!
            I couldn't figure out where I was going wrong but that makes perfect sense .
            Thanks so much again Catalin you're a genius!
            Regards
            Adam
            Flexchief
            • 3. Re: Air to Air LocalConnection error
              flexchief Level 1
              Could someone also please tell me how to send a message back from app2 to app1? I have tried it but i am getting Error #2044: Unhandled StatusEvent:. level=error, code=
              Flexchief
