8 Replies Latest reply on May 17, 2010 1:18 PM by pguerett
    renderPDFForm Service issue with XDP file
    rmh418
      I've been trying to create a workflow that will Render a PDF file from an XDP file created in Designer and some XML that was used for the dataconnection in the form.  So far I can get the process to work with the same form if it is saved as a PDF, but the workflow times out if I run this against a XDP file...Any suggestions of what I may be missing???
      Thanks!
