6 Replies Latest reply on May 16, 2010 12:26 PM by TeotiGraphix
    Flex4 equivalents for Flex3
    MageshR
      Hi - We are trying to rewrite the app in Flex3 to Flex4.  This is what we have in Flex3.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" backgroundColor="#FFFFFF"
          layout="absolute"  horizontalAlign="center" verticalAlign="middle" creationComplete="onCreationComplete();">
      We found the equivalent in Flex4 as below.
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                    creationComplete="onCreationComplete();" >
      But we are not able to do a horizontalAlign as center or VerticalAlign as middle. Pls help me on how to acheieve this.
      Also we have a VBox as below
      <mx:VBox  x="0" width="800" height="820" backgroundColor="#FFFFFF" verticalGap="0" borderColor="#402F5C" borderStyle="solid" cornerRadius="20">
      Again in Flex4 we have it as VGroup, but there is no equivalents for borderColor, borderStyle,cornerRadius and backgroundColor.  Pls help me on how to acheieve this.
        • 1. Re: Flex4 equivalents for Flex3
          SpaghettiCoder Level 3
          Use a border container
          with a layout of horizontal/vertical etc...
          • 2. Re: Flex4 equivalents for Flex3
            MageshR Level 1
            Can you give me a sample pls?
            Also how to achieve the 2nd part? i.e borderColor, borderStyle,cornerRadius and backgroundColor for a VGroup?
            • 3. Re: Flex4 equivalents for Flex3
              MageshR Level 1
              I tried nesting the VGroup inside a bordercontainer and that did the trick for 2nd part i.e adding borderradius etc.Thanks for that.
              For the 1st question, for horizontal align and vertical align for s:Application, I tried something similar below as you had sugegsted.
                  <s:BorderContainer>
                      <s:layout>
                          <s:HorizontalLayout horizontalAlign="center" verticalAlign="middle"
                              paddingLeft="5" paddingRight="5"
                              paddingTop="5" paddingBottom="5"/>
                      </s:layout>
              but it still does not do the align. The problem here is, its not showing the full application. it gets cut off at the page height level. But when I switch to
                  layout="absolute" xmlns:view="com.ca.view.*"   horizontalAlign="center" verticalAlign="middle" creationComplete="onCreationComplete();">
              it shows the full application. Pls help me. Its urgent.
              • 4. Re: Flex4 equivalents for Flex3
                If you have a screen shot of what it should look like it may be more helpful.
                But from your post, I'm thinking you're trying to do something like this below?
                <s:Application
                xmlns:s="
                xmlns:mx="
                library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" width="1024" height="768" preloaderChromeColor="#C46E6E" backgroundColor="#8D2E2E">
                <s:layout>
                <s:HorizontalLayout horizontalAlign="center" verticalAlign="middle"/>
                </s:layout>
                <s:BorderContainer cornerRadius="9">
                <s:layout>
                </s:layout>
                <s:Button label="Button"/>
                </s:BorderContainer>
                </s:Application>
                • 5. Re: Flex4 equivalents for Flex3
                  I indent my code, but this forum posting thing is stripping away the proper formatting *sigh*
                  • 6. Re: Flex4 equivalents for Flex3
                    TeotiGraphix Level 3
                    Using the absolute positioning of the Application you could use;
                        this would achieve a centered container using
                        the default BasicLayout of the Application
                    <s:BorderContainer
                        cornerRadius="20"
                        horizontalCenter="0" verticalCenter="0"
                        width="800" height="820">
                        <!-- acts like a VBox -->
                        <s:layout>
                            <!-- set any additional padding etc. -->
                            <s:VerticalLayout gap="0"/>
                        </s:layout>
                        <!-- Content elements... -->
                    Mike
