0 Replies Latest reply on May 15, 2010 6:35 PM by rudy713
    Flash UI Component Reference Point—Can It Be Changed?
    rudy713 Level 1
      When an image loads into the UI Component with the scaleContent parameter checked, it centers itself. With scaleContent unchecked, the images import in at the upper left corner If Is there a way to have the images load in at the upper right point? I, of course, changed the Registration/Transformation Point but this has had absolutely no effect. I'm using CS5 if it matters. Thanks for your help.
