1 Reply Latest reply on May 17, 2010 9:02 AM by Randy Edmunds
    Javascript cursor problem
    JonnyDL-HV74P1
      I have been trying to find a way to conditionally change the Icon via Javascript. I search the net and found the code/syntax, but when I use it, it compiles, but it doesn't work. My logic is obviously flawed. Can anybody see what I'm missing?
      What I want it to do:
      mouse over an thumbnail image, if its bigger brother(original/larger image) is visible do not change, otherwise change to a pointer and show the bigger brother. here is code I want the changes to occur in
      onMouseover call:
      function showAdSize(otherSize)
      switch(otherSize)
      case "300.0":
      if(width=="300.0")
      document.getElementById("medrecSize").style.visibility = "hidden";
      break;
      here is where I put the code to change the cursor for the other images to use the pointer
      (if its not 300.0 the change the other two will use the pointer)
      the code I found
      document.getElementById("medrecSize").style.cursor = "pointer";
      document.getElementById("leaderSize").style.visibility = "hidden";
      document.getElementById("medrecSize").style.visibility = "visible";
      document.getElementById("skySize").style.visibility = "hidden";
      break;
      case "728.0":
      if(width=="728.0")
      break;
      document.getElementById("leaderSize").style.visibility = "visible";
      break;
      case "160.0":
      if(width=="160.0")
      break;
      document.getElementById("skySize").style.visibility = "visible";
      break;
      Hopefully someone can see what I'm missing
