2 Replies Latest reply on May 17, 2010 8:18 AM by habaki1
    The debugger is the problem
    habaki1 Level 1
      Hello !
      I have a script that is called by the event manager on every events (the 'All' case) and i would like it can run without interference.
      But it seems that the Alt key launches the debugger when a script is running, despite a lot of standard commands use the Alt key: for instance to take a color (Alt) or even to go backwards in the history (Alt-ctrl-z).
      My problem is : the debugger window appears as soon as the alt key is pressed, and the script is halted. It is not the best behavior inside a client environment !!!!!
      My question is : how to turn off the display of the debugger in every cases, especially when the Alt key is pressed.
      My photoshop version is CS4.
      Thank you for your answers!
