6 Replies Latest reply on May 18, 2010 1:58 PM by kglad
    Drag and drop Query.
    vengod
      Hi all,
      i have this code for a drag and drop application.
      However, only mouth2_mc allows to be picked up and dropped - the others will only drop when another is selected? Hope this makes sense. How do i make them so they all allow me to drag AND drop.
      function pickupObject(event:MouseEvent):void{
      event.target.startDrag(true);
      function dropObject(event:MouseEvent):void{
      event.target.stopDrag();
      eye1_mc.addEventListener(MouseEvent.MOUSE_DOWN, pickupObject);
      eye1_mc.addEventListener(MouseEvent.MOUSE_UP, dropObject);
      eye2_mc.addEventListener(MouseEvent.MOUSE_DOWN, pickupObject);
      eye2_mc.addEventListener(MouseEvent.MOUSE_UP, dropObject);
      eye3_mc.addEventListener(MouseEvent.MOUSE_DOWN, pickupObject);
      eye3_mc.addEventListener(MouseEvent.MOUSE_UP, dropObject);
      mouth1_mc.addEventListener(MouseEvent.MOUSE_DOWN, pickupObject);
      mouth1_mc.addEventListener(MouseEvent.MOUSE_UP, dropObject);
      mouth2_mc.addEventListener(MouseEvent.MOUSE_DOWN, pickupObject);
      mouth2_mc.addEventListener(MouseEvent.MOUSE_UP, dropObject);
        • 1. Re: Drag and drop Query.
          use currentTarget instead of target.
          • 2. Re: Drag and drop Query.
            vengod Level 1
            Ok, so i changed each of the target words to say currentTarget and it
            hasnt affected the application?
            Code is now..
            event.currentTarget.startDrag(true);
            event.currentTarget.stopDrag();
            Thanks for trying though
            • 3. Re: Drag and drop Query.
              vengod Level 1
              This is still baffling me!
              • 4. Re: Drag and drop Query.
                then mouth2_mc is the only correct reference when your code executes (so, your other listener functions arent' being called).  to confirm, use the trace() function:
                trace(event.currentTarget.name);
                • 5. Re: Drag and drop Query.
                  vengod Level 1
                  i used the trace function, when tested the movie each of the movie clips appeared correct in the output. However, i could only drop mouth 2, the rest of the parts wont be put down.
                  Thanks.
                  • 6. Re: Drag and drop Query.
                    check (using trace again) if you have some kind of depth issue so the mouseups are not being detected.
