1 Reply Latest reply on May 18, 2010 7:21 AM by kglad
    Why I cann't control this mc's size
      Hey Everyone,
      What I did was simple: I loaded a swf into an empty MovieClip,
      ActionScript Code:
      mc_BG_Container._x = 4;
      mc_BG_Container._y = 5;
      background.swf's stage was set up with 300X200 aspect-ratio, but it was further larger than that size when I tested it. Could someone kindly tell me why?
      Beside from that, I found I couldn't operate on  mc_BG_Container's width and height, if I append this piece of code:
      ActionScript Code:
      mc_BG_Container._width = Stage.width - 426;
      the mc_BG_Container will not show up. Why is that?
      Thanks a lot.
        • 1. Re: Why I cann't control this mc's size
          if mc_BG_Container is a movieclip that's undergone no transformations, your swf will load at its native size.  if you change the target's scale, you'll have problems.
          it's usually best to create a new empty movieclip to use for an as2 load-target.
          then, if you want to resize from the native size, you must wait until loading is complete before transforming the load-target.  (then don't re-use it for another load-target or you'll run into the problem mentioned in the first paragraph.)
