5 Replies Latest reply on Aug 30, 2012 9:31 AM by irongamer
    abc bytecode decoding failed.
    Starlover_jacob Level 1
      Please some help here,
      I updated my sdk version to 3.5.0.12683
      I also tried version 3.4.1.10084
      and 3.4.0.6955
      When i create a simple project like this:
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" height="501" width="967">
           <mx:Image source="@Embed('img/eagle.jpg')"  x="481" y="10"/>
      </mx:WindowedApplication>
      I still get the abc bytecode decoding failed error.
      Anyone a solution?
        • 1. Re: abc bytecode decoding failed.
          TeotiGraphix Level 3
          Sounds like your project needs to be cleaned. Project -> Clean
          If for some reason that doesn't work for testing purposes, try creating another project. If that doesn't work, for more testing purposes, try creating a new workspace and a new project. Sometimes the metadata cache in Eclipse acts weird when changing SDKs.
          Are you using FlexBuilder 3 or FlashBuilder 4?
          Mike
          • 2. Re: abc bytecode decoding failed.
            Cleaning the project did the job,
            Thanks!
            • 3. Re: abc bytecode decoding failed.
              sicowan2012
              Hi, I have several ADOBE AIR Flex 3 projects that I like to run from the debugger to do jobs such as batch updating XML documents.
              Trouble is I have migrated to Windows 7 and updated from AIR 1.5 to 2.6.
              I downloaded and added the new SDK which gave me errors such as versionNumber cannot be null. Well I got that sorted and now it complains with "initial content not found".
              I see that there is not an swf in the bin-release or bin-debug folder so having tried to Export a release build I get a heap of errors saying my.mxml: abd bytecode decoding failed.
              I have tried using the "clean project" setting up a new project but all these end up with the same result.
              I am a bit lost in this. Can anyone help?
              Cheers
              Simon
              • 4. Re: abc bytecode decoding failed.
                Flex harUI Adobe Employee
                Make sure you can build a simple test project.  If you can't figure that out
                first.
                Then when working with your old project, make sure all SWCs have been
                updated to the same SDK version.
                • 5. Re: abc bytecode decoding failed.
                  irongamer
                  Why does this happen so often?  I have to clean my project whenever I first open Flash Builder each day.  Are there some changes in the future that will make this not happen so often?  I'm running Flash Builder 4.6.0.23201.
                  My project does include a number of source paths from another drive including: GTween, as3-signals, starling, and foxhole.  I have no SWC's in the build library.
