5 Replies Latest reply on Dec 21, 2010 4:09 AM by asbestos girl
    spark Panel header?
    kss587
      is there a option to remove the header of the spark panel..similar to the one in flex3 where we set <mx:panel headerHeight=0 />
        • 1. Re: spark Panel header?
          TeotiGraphix Level 3
          Without having to copy the almost 300 lines of PanelSkin code to do this you could try.
                         xmlns:mx="library://ns.adobe.com/flex/mx">
              <fx:Script>
                  <![CDATA[
                      import mx.events.FlexEvent;
                      import spark.skins.spark.PanelSkin;
                      protected function panel_creationCompleteHandler(event:FlexEvent):void
                          var skin:PanelSkin = panel.skin as PanelSkin;
                          skin.topGroup.includeInLayout = false;
                          skin.topGroup.visible = false;
              </fx:Script>
              <s:Panel id="panel"
                       title="Not going to see ME!"
                       creationComplete="panel_creationCompleteHandler(event)">
                  <s:List/>
              </s:Panel>
          </s:Application>
          Depending on your needs, you may just create a simple subclass that implements the topGroup hidding.
          Mike
          • 2. Re: spark Panel header?
            kss587 Level 1
            Hi Mike,
            The solution you gave is much simpler.
            Thank you so much. But the problem is that the spark panel i have is the root tag of a mxml component.then how do i get the reference ?
            But now i am  using a skin class with this line of code.
            <s:Group
            id="padding" width="100%" height="100%">
            <s:Group id="contentGroup" top="0" left="0" right="0" bottom="0" minWidth="0" minHeight="0">
            </s:Group>
            This  renders the header invisible.But i would still like to proceed with your approach. How do i get the reference for such root tags?
            • 3. Re: spark Panel header?
              <s:Panel xmlns:fx="http://ns.adobe.com/mxml/2009"
                  <fx:Script>
                      <![CDATA[
                              var skin:PanelSkin = skin as PanelSkin;
                  </fx:Script>
              </s:
              Panel>
              This is how you would do the same thing a a Panel MXML component.
              Mike
              • 4. Re: spark Panel header?
                David_F57 Level 5
                hi,
                If your happy just to hide the header at run time....
                <s:Panel id="pnl" x="90" y="116" width="250" height="200" creationComplete="pnl.titleDisplay.height=pnl.titleDisplay.minHeight=0" >
                David.
                [edit] do you need to use a panel, there is always borderContainer.
                • 5. Re: spark Panel header?
                  asbestos girl
                  Thank you, I had the same issue and simply changing to s:BorderContainer did the trick in the simplest way.
