1 Reply Latest reply on May 17, 2010 8:47 AM by Todd_Kopriva
    No DV Stream export in CS5?
    alatriste12
      Is there a way to export DV stream files in AE CS5? I use to do this in CS4 and CS3
      but now on CS5 there is no DV export anymore I just see Flash export.
      I tryed to use the Rendre Queue, but it wasn't there too.
      Thanks!
        • 1. Re: No DV Stream export in CS5?
          Todd_Kopriva Level 8
          The DV stream exporter was a QuickTime exporter, installed to the File > Export menu by QuickTime. Apple doesn't supply a 64-bit version of QuickTime, so QuickTime can no longer directly install things in that menu.
          If the DV stream export functionality from the render queue is important to you, then please file a feature request.
          For now, you can create a losslessly encoded movie from After Effects and use QuickTime Pro to convert the video to a DV stream.
