0 Replies Latest reply on May 17, 2010 8:45 AM by Ugo Ducharme
    EXCEPTION_ACCESS_VIOLATION : MyEclipse + FlexBuilder 3 Plug-in
    Ugo Ducharme
      I have MyEclipse 7.5 with FlexBuilder 3 Professional Plug-in installed.  Everything works fine except when I Edit a MXML file in Design mode, the  whole JVM exits with a EXCEPTION_ACCESS_VIOLATION.
      Looking at the call stack, I can see that the problem comes from SWT  that uses a DLL for drawing a rectangle.
      I copy here the full exception log to give you more information:
      # A fatal error has been detected by the Java Runtime Environment:
      #  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6782bf5e, pid=236,  tid=2888
      # JRE version: 6.0_20-b02
      # Java VM: Java HotSpot(TM) Client VM (16.3-b01 mixed mode windows-x86 )
      # Problematic frame:
      # C  [gdiplus.dll+0x1bf5e]
      # If you would like to submit a bug report, please visit:
      #   http://java.sun.com/webapps/bugreport/crash.jsp
      # The crash happened outside the Java Virtual Machine in native code.
      # See problematic frame for where to report the bug.
      ---------------  T H R E A D  ---------------
      Current thread (0x00396c00):  JavaThread "main" [_thread_in_native,  id=2888, stack(0x009c0000,0x00a10000)]
      siginfo: ExceptionCode=0xc0000005, writing address 0xa972b2e8
      Registers:
      EAX=0x67b5bfd0, EBX=0x00000001, ECX=0x41bcf318, EDX=0xfff7f7f8
      ESP=0x00a0e6c8, EBP=0x00a0e6c8, ESI=0x67ad30b0, EDI=0x67ad3078
      EIP=0x6782bf5e, EFLAGS=0x00250202
      Top of Stack: (sp=0x00a0e6c8)
      0x00a0e6c8:   00a0e6e4 6781f3a3 000001ce 67ad3078
      0x00a0e6d8:   a972b2e8 67ad3060 000004ba 00a0e73c
      0x00a0e6e8:   678eaaa2 a972b2e8 67b5bfd0 000001cf
      0x00a0e6f8:   000004ba 0000006d 00000000 67ad48a8
      0x00a0e708:   67ad3060 a9650000 67ad3060 a9650000
      0x00a0e718:   00000004 00000000 00000000 000001cf
      0x00a0e728:   00000000 00000004 00000001 000004ba
      0x00a0e738:   67b5bfd0 00a0e78c 678eac57 00002000
      Instructions: (pc=0x6782bf5e)
      0x6782bf4e:   ec 83 7d 08 00 8b c2 74 13 2b c8 8b 10 ff 4d 08
      0x6782bf5e:   89 14 08 83 c0 04 83 7d 08 00 75 ef 5d c2 08 00
      Stack: [0x009c0000,0x00a10000],  sp=0x00a0e6c8,  free space=13900a0e1fck
      Native frames: (J=compiled Java code, j=interpreted, Vv=VM code,  C=native code)
      C  [gdiplus.dll+0xf3a3]
      C  [gdiplus.dll+0xdaaa2]
      C  [gdiplus.dll+0xdac57]
      C  [gdiplus.dll+0x79c24]
      C  [gdiplus.dll+0x16d7b]
      C  [gdiplus.dll+0xf2c0]
      C  [gdiplus.dll+0x4d5d5]
      C  [gdiplus.dll+0x67e97]
      C  [gdiplus.dll+0x4ce1c]
      C  [gdiplus.dll+0x4d34b]
      C  [gdiplus.dll+0x6e46b]
      C  [gdiplus.dll+0x6e352]
      C  [gdiplus.dll+0x6e2eb]
      C  [gdiplus.dll+0x4d294]
      C  [swt-gdip-win32-3452.dll+0x219c]
      j  org.eclipse.swt.internal.gdip.Gdip.Graphics_FillRectangle(IIIIII)I+0
      j  org.eclipse.swt.graphics.GC.fillRectangle(IIII)V+74
      j   org.eclipse.swt.graphics.GC.fillRectangle(Lorg/eclipse/swt/graphics/Rectangle;)V+25
      j   com.adobe.flexbuilder.editors.common.ui.pi.form.SectionHeading.doPaintHeading(Lorg/eclips e/swt/events/PaintEvent;)V+61
      j   com.adobe.flexbuilder.editors.common.ui.pi.form.SectionHeading$1.paintControl(Lorg/eclips e/swt/events/PaintEvent;)V+5
      j   org.eclipse.swt.widgets.TypedListener.handleEvent(Lorg/eclipse/swt/widgets/Event;)V+947
      J   org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/swt/widgets/Event;)V
      J   org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/widgets/Event;Z)V
      j   org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/widgets/Event;)V+4
      j   org.eclipse.swt.widgets.Composite.WM_PAINT(II)Lorg/eclipse/swt/internal/win32/LRESULT;+14 14
      J  org.eclipse.swt.widgets.Control.windowProc(IIII)I
      J  org.eclipse.swt.widgets.Display.windowProc(IIII)I
      v  ~StubRoutines::call_stub
      V  [jvm.dll+0xf049c]
      V  [jvm.dll+0x17fcf1]
      V  [jvm.dll+0xf051d]
      V  [jvm.dll+0xf9e0f]
      V  [jvm.dll+0xfbc37]
      C  [swt-win32-3452.dll+0x1465]
      C  0x677e0018
      C  [USER32.dll+0x8734]
      C  [USER32.dll+0x8816]
      C  [USER32.dll+0x18ea0]
      C  [USER32.dll+0x18eec]
      C  [ntdll.dll+0xe473]
      C  [USER32.dll+0x8a10]
      C  [swt-win32-3452.dll+0x35be]
      J   org.eclipse.swt.internal.win32.OS.DispatchMessageW(Lorg/eclipse/swt/internal/win32/MSG;)I
      J  org.eclipse.swt.widgets.Display.readAndDispatch()Z
      J   org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptio nHandler;Lorg/eclipse/swt/widgets/Display;)V
      j  org.eclipse.ui.internal.Workbench.runUI()I+393
      j   org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
      j  org.eclipse.ui.internal.Workbench$5.run()V+23
      j   org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databindin g/observable/Realm;Ljava/lang/Runnable;)V+12
      j   org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display; Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
      j   org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/ecl ipse/ui/application/WorkbenchAdvisor;)I+2
      j   org.eclipse.ui.internal.ide.application.IDEApplication.start(Lorg/eclipse/equinox/app/IAp plicationContext;)Ljava/lang/Object;+84
      j   org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Objec t;+135
      j   org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Ob ject;)Ljava/lang/Object;+103
      j   org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Lja va/lang/Object;+29
      j   org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object; +149
      j   org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnabl e;)Ljava/lang/Object;+183
      V  [jvm.dll+0xf049c]
      V  [jvm.dll+0xf051d]
      V  [jvm.dll+0x199ceb]
      V  [jvm.dll+0x19a706]
      V  [jvm.dll+0x11bc03]
      C  [java.dll+0x714d]
      j   sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/l ang/Object;+87
      j   sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Lja va/lang/Object;+6
      j   java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+ 161
      j   org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+21 1
      j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+114
      j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
      j  org.eclipse.equinox.launcher.Main.main([Ljava/lang/String;)V+10
      V  [jvm.dll+0xf049c]
      V  [jvm.dll+0xf051d]
      V  [jvm.dll+0xf9bc5]
      V  [jvm.dll+0x10181d]
      C  [javaw.exe+0x2155]
      C  [javaw.exe+0x8614]
      C  [kernel32.dll+0xb729]
      Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
      j   sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object; [Ljava/lang/Object;)Ljava/lang/Object;+0
      ---------------  P R O C E S S  ---------------
      Java Threads: ( => current thread )
      0x7a05bc00 JavaThread "Design Model Updater" daemon [_thread_blocked,  id=3588, stack(0x6c420000,0x6c470000)]
      0x78ece000 JavaThread  "com.adobe.flexbuilder.editors.mxml.code.NamespaceChangedReconciler"  daemon [_thread_blocked, id=3228, stack(0x6c3d0000,0x6c420000)]
      0x79ed5400 JavaThread  "com.adobe.flexbuilder.editors.common.editor.IdleTypingReconciler"  daemon [_thread_blocked, id=2768, stack(0x6c330000,0x6c380000)]
      0x7a075800 JavaThread "Thread-15" daemon [_thread_blocked, id=308,  stack(0x6c380000,0x6c3d0000)]
      0x79e44400 JavaThread "AWT-Windows" daemon [_thread_in_native,  id=3872, stack(0x6c000000,0x6c050000)]
      0x79db5800 JavaThread "Java2D Disposer" daemon [_thread_blocked,  id=2272, stack(0x6bec0000,0x6bf10000)]
      0x789ff800 JavaThread "Worker-10" [_thread_blocked, id=2084,  stack(0x6bf60000,0x6bfb0000)]
      0x7aa20c00 JavaThread "Timer-3" daemon [_thread_blocked, id=1400,  stack(0x6be70000,0x6bec0000)]
      0x7a780000 JavaThread "Timer-2" daemon [_thread_blocked, id=1720,  stack(0x6be20000,0x6be70000)]
      0x787cd400 JavaThread "org.eclipse.jdt.debug: JDI Event Dispatcher"  daemon [_thread_blocked, id=3712, stack(0x6bc90000,0x6bce0000)]
      0x787cdc00 JavaThread "Packet Send Manager" daemon [_thread_blocked,  id=392, stack(0x6bd30000,0x6bd80000)]
      0x785a0400 JavaThread "Packet Receive Manager" daemon  [_thread_in_native, id=812, stack(0x6bce0000,0x6bd30000)]
      0x68bc3800 JavaThread "Process monitor" daemon [_thread_in_native,  id=3684, stack(0x6bc40000,0x6bc90000)]
      0x7857e400 JavaThread "Input Stream Monitor" daemon [_thread_blocked,  id=2144, stack(0x6bbf0000,0x6bc40000)]
      0x78071400 JavaThread "Output Stream Monitor" daemon  [_thread_in_native, id=3852, stack(0x6bba0000,0x6bbf0000)]
      0x69ec6c00 JavaThread "Output Stream Monitor" daemon  [_thread_in_native, id=3268, stack(0x6bb50000,0x6bba0000)]
      0x785b8400 JavaThread "Timer-1" [_thread_blocked, id=1140,  stack(0x6b3f0000,0x6b440000)]
      0x68bbb400 JavaThread "Timer-0" [_thread_blocked, id=3632,  stack(0x6b370000,0x6b3c0000)]
      0x68b8fc00 JavaThread "MyEclipse Thread" [_thread_blocked, id=3736,  stack(0x6b300000,0x6b350000)]
      0x780b1000 JavaThread "Cleanup" daemon [_thread_in_native, id=1604,  stack(0x6aec0000,0x6af10000)]
      0x78097400 JavaThread "Worker-8" [_thread_blocked, id=3396,  stack(0x6ae20000,0x6ae70000)]
      0x78133400 JavaThread "Worker-4" [_thread_blocked, id=3832,  stack(0x6ace0000,0x6ad30000)]
      0x78122400 JavaThread "Worker-3" [_thread_blocked, id=2812,  stack(0x6ac90000,0x6ace0000)]
      0x7811cc00 JavaThread "Worker-2" [_thread_blocked, id=1540,  stack(0x6ac40000,0x6ac90000)]
      0x78112400 JavaThread "JavaScript indexing" daemon [_thread_blocked,  id=3380, stack(0x6a880000,0x6a8d0000)]
      0x6a03fc00 JavaThread "Java indexing" daemon [_thread_blocked,  id=3468, stack(0x6a670000,0x6a6c0000)]
      0x68b80000 JavaThread "Worker-1" [_thread_blocked, id=2028,  stack(0x67e30000,0x67e80000)]
      0x69de8400 JavaThread "Provisioning Event Dispatcher" daemon  [_thread_blocked, id=3080, stack(0x67390000,0x673e0000)]
      0x64ec0400 JavaThread "Start Level Event Dispatcher" daemon  [_thread_blocked, id=3352, stack(0x656f0000,0x65740000)]
      0x651a6800 JavaThread "Framework Event Dispatcher" daemon  [_thread_blocked, id=208, stack(0x656a0000,0x656f0000)]
      0x64ea1000 JavaThread "Low Memory Detector" daemon [_thread_blocked,  id=732, stack(0x650f0000,0x65140000)]
      0x64e9bc00 JavaThread "CompilerThread0" daemon [_thread_blocked,  id=2200, stack(0x650a0000,0x650f0000)]
      0x64e99400 JavaThread "Attach Listener" daemon [_thread_blocked,  id=2880, stack(0x65050000,0x650a0000)]
      0x64e98000 JavaThread "Signal Dispatcher" daemon [_thread_blocked,  id=2308, stack(0x65000000,0x65050000)]
      0x64e87c00 JavaThread "Finalizer" daemon [_thread_blocked, id=2608,  stack(0x64fb0000,0x65000000)]
      0x64e83000 JavaThread "Reference Handler" daemon [_thread_blocked,  id=740, stack(0x64f60000,0x64fb0000)]
      =>0x00396c00 JavaThread "main" [_thread_in_native, id=2888,  stack(0x009c0000,0x00a10000)]
      Other Threads:
      0x64e80400 VMThread [stack: 0x64f10000,0x64f60000] [id=3260]
      0x64eabc00 WatcherThread [stack: 0x65140000,0x65190000] [id=772]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      def new generation   total 157248K, used 39685K [0x02a90000,  0x0d530000, 0x17fe0000)
      eden space 139776K,  15% used [0x02a90000, 0x04041620, 0x0b310000)
      from space 17472K, 100% used [0x0c420000, 0x0d530000, 0x0d530000)
      to   space 17472K,   0% used [0x0b310000, 0x0b310000, 0x0c420000)
      tenured generation   total 349568K, used 180984K [0x17fe0000,  0x2d540000, 0x42a90000)
      the space 349568K,  51% used [0x17fe0000, 0x2309e138, 0x2309e200,  0x2d540000)
      compacting perm gen  total 262144K, used 110140K [0x42a90000,  0x52a90000, 0x62a90000)
      the space 262144K,  42% used [0x42a90000, 0x4961f358, 0x4961f400,  0x52a90000)
      No shared spaces configured.
      Dynamic libraries:
      0x00400000 - 0x00424000      C:\Program Files\Java\jdk1.6.0_20\bin\javaw.exe
      0x7c900000 - 0x7c9b2000      C:\WINDOWS\system32\ntdll.dll
      0x7c800000 - 0x7c8f6000      C:\WINDOWS\system32\kernel32.dll
      0x77dd0000 - 0x77e6b000      C:\WINDOWS\system32\ADVAPI32.dll
      0x77e70000 - 0x77f02000      C:\WINDOWS\system32\RPCRT4.dll
      0x77fe0000 - 0x77ff1000      C:\WINDOWS\system32\Secur32.dll
      0x7e410000 - 0x7e4a1000      C:\WINDOWS\system32\USER32.dll
      0x77f10000 - 0x77f59000      C:\WINDOWS\system32\GDI32.dll
      0x76390000 - 0x763ad000      C:\WINDOWS\system32\IMM32.DLL
      0x7c340000 - 0x7c396000      C:\Program  Files\Java\jdk1.6.0_20\jre\bin\msvcr71.dll
      0x6d8b0000 - 0x6db47000      C:\Program  Files\Java\jdk1.6.0_20\jre\bin\client\jvm.dll
      0x76b40000 - 0x76b6d000      C:\WINDOWS\system32\WINMM.dll
      0x6d860000 - 0x6d86c000      C:\Program  Files\Java\jdk1.6.0_20\jre\bin\verify.dll
      0x6d3e0000 - 0x6d3ff000      C:\Program  Files\Java\jdk1.6.0_20\jre\bin\java.dll
      0x6d340000 - 0x6d348000      C:\Program  Files\Java\jdk1.6.0_20\jre\bin\hpi.dll
      0x76bf0000 - 0x76bfb000      C:\WINDOWS\system32\PSAPI.DLL
      0x6d8a0000 - 0x6d8af000      C:\Program  Files\Java\jdk1.6.0_20\jre\bin\zip.dll
      0x72000000 - 0x72014000      C:\Program  Files\Genuitec\Common\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.101.R34x_v 20080731\eclipse_1115.dll
      0x773d0000 - 0x774d3000       C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x- ww_35d4ce83\COMCTL32.dll
      0x77c10000 - 0x77c68000      C:\WINDOWS\system32\msvcrt.dll
      0x77f60000 - 0x77fd6000      C:\WINDOWS\system32\SHLWAPI.dll
      0x77c00000 - 0x77c08000      C:\WINDOWS\system32\VERSION.dll
      0x74720000 - 0x7476c000      C:\WINDOWS\system32\MSCTF.dll
      0x755c0000 - 0x755ee000      C:\WINDOWS\system32\msctfime.ime
      0x774e0000 - 0x7761d000      C:\WINDOWS\system32\ole32.dll
      0x653f0000 - 0x65428000      C:\WINDOWS\system32\UxTheme.dll
      0x65430000 - 0x65439000      C:\WINDOWS\system32\mslbui.dll
      0x68000000 - 0x68036000      C:\WINDOWS\system32\rsaenh.dll
      0x769c0000 - 0x76a74000      C:\WINDOWS\system32\USERENV.dll
      0x65560000 - 0x655b5000      C:\WINDOWS\system32\netapi32.dll
      0x6d6c0000 - 0x6d6d3000      C:\Program  Files\Java\jdk1.6.0_20\jre\bin\net.dll
      0x71ab0000 - 0x71ac7000      C:\WINDOWS\system32\WS2_32.dll
      0x71aa0000 - 0x71aa8000      C:\WINDOWS\system32\WS2HELP.dll
      0x71a50000 - 0x71a8f000      C:\WINDOWS\System32\mswsock.dll
      0x76f20000 - 0x76f47000      C:\WINDOWS\system32\DNSAPI.dll
      0x76fb0000 - 0x76fb8000      C:\WINDOWS\System32\winrnr.dll
      0x76f60000 - 0x76f8c000      C:\WINDOWS\system32\WLDAP32.dll
      0x76fc0000 - 0x76fc6000      C:\WINDOWS\system32\rasadhlp.dll
      0x6d6e0000 - 0x6d6e9000      C:\Program  Files\Java\jdk1.6.0_20\jre\bin\nio.dll
      0x673e0000 - 0x67435000      C:\Program Files\Genuitec\MyEclipse  7.0\configuration\org.eclipse.osgi\bundles0 0x67810000 - 0x679bb000       C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6001.22319_x-ww_f0b4 c2df\gdiplus.dll
      0x65650000 - 0x65658000      C:\Program Files\Genuitec\MyEclipse  7.0\configuration\org.eclipse.osgi\bundles1 0x76380000 - 0x76385000      C:\WINDOWS\system32\msimg32.dll
      0x65670000 - 0x6567f000      C:\Program Files\Genuitec\MyEclipse  7.0\configuration\org.eclipse.osgi\bundles4 0x6cae0000 - 0x6cf1a000      C:\Program Files\Genuitec\MyEclipse  7.0\configuration\org.eclipse.osgi\bundles Launcher Type: SUN_STANDARD
      Environment Variables:
      CLASSPATH=.;C:\Program Files\Java\jre6\lib\ext\QTJava.zip
      PATH=C:\oracle\product.2.0\client_1\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System3 2\Wbem;C:\Program  Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common  Files\Roxio  Shared.0\DLLShared\;C:\WINDOWS\system32\WindowsPowerShell\v1.0;C:\Program  Files\QuickTime\QTSystem\;C:\WINDOWS\System32\Wbem
      USERNAME=ugod
      OS=Windows_NT
      PROCESSOR_IDENTIFIER=x86 Family 6 Model 37 Stepping 2, GenuineIntel
      ---------------  S Y S T E M  ---------------
      OS: Windows XP Build 2600 Service Pack 3
      CPU:total 2 (8 cores per cpu, 2 threads per core) family 6 model 37  stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1,  sse4.2, popcnt, ht
      Memory: 4k page, physical 3071160k(1668472k free), swap  5001108k(3356124k free)
      vm_info: Java HotSpot(TM) Client VM (16.3-b01) for windows-x86 JRE  (1.6.0_20-b02), built on Apr 12 2010 13:52:23 by "java_re" with MS VC++  7.1 (VS2003)
      time: Mon May 17 11:17:51 2010
      elapsed time: 2002 seconds
      Can someone suggestion me a work around or any kind of action I can  take?
