3 Replies Latest reply on May 21, 2010 1:26 PM by jimmy_pop
    Find and place CS4 JS
    jimmy_pop
      Hi all,
      I would like the script to run through each line of the file, search the  InDesign file for that number, and if it finds it place the icon I  specify after the text it just found. Here is some pseduo code I've been trying to figure out by piecing together other scripts.
      while(input.hasNext())
           var text = input.nextLine();
           if(textExists == true)
                app.findTextPreferences.findWhat = text;
                app.changeTextPreferences.changeTo = text + " " + place("C:\\catalog\\icons\\Icon_install.ai") after the text  found;
                myDocument.changeText();
           else
                go to the next line
      I would be using a text file that has part numbers in it like
      4005
      4003
      5007
      etc
      I know a bit of java from school but not much JS. I'm really sorry for being so sloppy, but I'm new to JS. Any help would be appreciated.
        • 1. Re: Find and place CS4 JS
          Harbs. Level 6
          Do you need the same icon each time or a different icon for each?
          If it's the same icon, you have two options:
          1) You can copy it to the clipboard and use find/change to insert the clipboard contents (like you would in the UI).
          2) You can serach the document and use iterate through the finds using
          finds[i].insertionPoints[-1].place(myFile)
          or (if it's in the clipboard)
          app.select(finds[i].insertionPoints[-1])
          app.paste()
          Harbs
          • 2. Re: Find and place CS4 JS
            jimmy_pop Level 1
            Yes I will be using one icon per list of numbers. Are you saying to put all of the part numbers in an array? Also, I don't want to replace the contents of what I find, I just want to add the icon directly after the number it has found.
            • 3. Re: Find and place CS4 JS
              jimmy_pop Level 1
              var finds = new Array("66782","67575");
              for(var i = 0; i < finds.length; i++)
                   app.findTextPreferences.findWhat = finds[i];
                   app.select(finds[i].insertionPoints[-1]);
                   app.paste();
              I just used two part numbers to test this. When I try to run it it gives me an error 21: undefined is not an object on line 6 which is the app.select statement. Any idea?
