2 Replies Latest reply on May 26, 2010 6:49 AM by Umal Kumar
    Problem with the configuration of a data service
    Rafael Viana
      I'm facing some strange problems to get the CRM sample to run.
      Firstly, I ran it from the lcds-samples.war, and it works perfectly, but when I build an Eclipse project: New -> Dynamic Web Project ( exactly how I made when works on BlazeDS ), put the libraries and the configuration files ( the same as the lcds-samples.war ) I got an error when the Tomcat starts:
      flex.messaging.config.ConfigurationException: Unrecognized tag found
      in <properties>.  Please consult the documentation to determine if the
      tag is invalid or belongs inside of a different tag:
        '/server/fill-method' in destination with id: 'crm-company' from
      file: data-management-config.xml
        '/server/fill-method' in destination with id: 'crm-employee' from
      P.S: I tried also with the 'fill-method' tag outside the 'server' tag and also the tag as only 'fill'.
      The compiler is saying that the fill-method tag is unrecognized and I need to consult the documentation.Right...
      In the Adobe Livecycle Data Services ES2 3.1 documentation (updated 5/3/2010) in the page 255 contains a table with the tags accepted to configure a destination with a Custom Assembler, and one of these properties is the fill-method.
      I tried also to remove this tag fill-method.And now it compiles!
      However when I run the project.Throw me an error:
      Missing or invalid configuration for destinations: ["crm-company","crm-
      employee"]
      Could not initialize DataService
