1 Reply Latest reply on May 17, 2010 4:23 PM by TeotiGraphix
    How would you structure this...
    SpaghettiCoder Level 3
      If you have two flex apps that share 1 common directory?
      When you Export to release build in flex, it'll output them into two seperate directories, how would you get them both to share 1 common directory to access things
      [ Release Build ]
      htdocs/project1
      htdocs/project2
      [ Trying to get them to share a directory that is one level up from where project1 and project2 are ]
      htdocs/pictures
        • 1. Re: How would you structure this...
          TeotiGraphix Level 3
          So are you saying you want to share an assets directory?
          If you knew that your directory structure wasn't going to change you could use reletive paths when targeting the assets.
          I think you can also add the actual htdocs/pictures directory as an external src folder as well ( in both projects ). I know for sure you can use the include directive like this though.
          Right click -> Properties -> SourcePath -> Add Folder
          Mike
