5 Replies Latest reply on May 18, 2010 10:00 PM by Vincent-ZHANG
    How can I make Tweener work?
    Vincent-ZHANG Level 1
      Hi There,
      Recently I found Tweener (http://code.google.com/p/tweener/).
      And I followed the instruction of installment, but I got a compiler error:
      Desc: The class or interface 'caurina.transitions.Equations' could not be loaded.
      Sour: import caurina.transitions.Equations;
      Even I run the samples downloaded from the website, I got the errors, could someone tell me why is that?
      Thanks a lot.
        • 1. Re: How can I make Tweener work?
          you probably don't have the class files saved in the correct directory.
          • 2. Re: How can I make Tweener work?
            Well, that is quite unlikely, since I got the same result
            even from official samples.
            I put caurina folder under the root folder of the project.
            • 3. Re: How can I make Tweener work?
              Ok, maybe it is not quite clear.....
              Further explainations:
              I put the folder caurina under the root folder of my project, namely the same directory as myPro.fla.
              And in the fla, there is piece of code:
              import caurina.transitions.Tweener;
              there are many other classes' files located in caurina\transitions\
              and Tweener import most of them, by using import  caurina.transitions.Equations;
              but this caused the errors....
              Could someone help to figure it out? thanks.
              • 4. Re: How can I make Tweener work?
                do you see Equations.as in caurina/transitions?
                if yes, did you change anything in Equations.as?
                and, is there any reason you're importing any of those classes (other than Tweener)?
                • 5. Re: How can I make Tweener work?
                  Hi kglad,
                  Thanks for your attention. Finally, I solved the problem last night. I have to say it is a little bit weird, weird problem and weird solution.
                  The conclusion can be drawn just by following the steps:
                  1. Go to http://tweener.googlecode.com/svn/trunk/examples/
                     and download displacedHeart_as2_flash8.zip
                  2. Unzip the file, get the folder with all the assets.
                  3. Open the fla file with Flash CS3 or Flash 8, go to control->test Movie directly. You should see some errors, the 1st one should be something like
                     'Equations can not be loaded.......'
                  4. Go to \caurina\transitions, open Equations.as with editer, cut (not delete, since we need it back later) one piece of code at the end of the file, and
                     save it.
                  5. Test Movie again, should see some new syntax errors..
                  6. Copy back the piece of code to the end of Equations.as,  and save it.
                  7. Test Movie again, everything goes well.
                  Besides, I solved the same problem with MC Tween by using the same approach. The sample I used to perform my trial was 'leaves'.
                  It seems that there is a bug in Flash's compiler.
