1. Re: recreating merged curves layer by guesswork
Craig F May 18, 2010 9:40 AM (in response to Christian Davideck)There is no formulated way to do it. It's all about a visual adjustment and some recollection on your part.
2. Re: recreating merged curves layer by guesswork
Jeremy AB May 18, 2010 11:37 AM (in response to Christian Davideck)What about using the Match Color command under Image>Adjust?
It won't give you an adjustment layer but should be able to make the source image look like the PNG.
3. Re: recreating merged curves layer by guesswork
Christian Davideck May 18, 2010 12:14 PM (in response to Jeremy AB)thank you Jeremy, but /match color/ doesn't give me satisfactory results
(luminosity does obviously not match at all, even colours don't seem to
match too well) plus I'd need a non-distructive adjustment layer.
What I will try next is use the 1x1 color picker and a sheet of paper
and calculate the multipliers I need to go from source to target. I
don't think it will work, but I'll give it a try ...
... don't hesitate if you have other good ideas. Thank you.
4. Re: recreating merged curves layer by guesswork
Gyno-jiz May 18, 2010 12:16 PM (in response to Christian Davideck)I think the fact that multiple curves were applied will make this difficult.
5. Re: recreating merged curves layer by guesswork
Christian Davideck May 18, 2010 12:31 PM (in response to Gyno-jiz)@JMaloney:
yes, R,G and B curves were applied. But I also have an R,G,B color
picker so ...
but you are of course right that it will be difficult and probably won't
work ...
6. Re: recreating merged curves layer by guesswork
Gyno-jiz May 18, 2010 1:05 PM (in response to Christian Davideck)If its just one curve, you can probably do it. But an additional master adjustment might prove too much if the changes were drastic. Still worth a go. Even if you just place the 4 color samplers in quarter tones, you might have some luck. You inspired me to finally get at what Martin Evening was doing below. If you only had a gray strip in each channel...
http://photoshopnews.com/2007/09/05/how-to-express-blend-modes-as-curves/
7. Re: recreating merged curves layer by guesswork
Christian Davideck May 18, 2010 1:22 PM (in response to Gyno-jiz)If its just one curve, you can probably do it. But all three, plus a master adjustment might prove too much if the change were drastic. Still worth a go. Even if you just place the 4 color samplers in quarter tones, you might have some luck.
As I said above, it doesn't matter whether it's 1 or 3 curves, because
the RGB channels are treated independently (both by color picker and the
curves layer). The master adjustment is more problematic, right,
but theoretically it shouldn't be a problem either, because two curves
can be "merged" ... well, not in Photoshop (I might suggest that as a
feature one day), but mathematically.
Curves are functions. Take an easy function like f(x) = 1.5*x + 2x
this equates to: f(x) = 1.75 * x
(where x = input and f(x) = output in Photoshop curves adjustment)
I have started working with this method and so far it looks promising,
hope it turns out right
I'll let you know
Looks very interesting. I'll have a look at it one rainy day ...
