6 Replies Latest reply on May 21, 2010 1:19 AM by TonKuypers
    Exporting each layers as separate PDF
    vikash_k85
      Hello,
      I am trying to export each layer in an ID cs3 document as a PDF file.  Any help is welcome.
      What i have done so far is creating a temporary document for each layer, copy/paste the layer contents to that temp doc and exporting the document as pdf.  But i am having problem with big layers when copy/paste due to the size limit of the clipboard.  Is there a way to simply export each layers to a separate pdf file without copy/pasting. Thanks
      var targetDocument = app.documents[0];
      activeDocument = targetDocument;
      layerCount = targetDocument.layers.length;
      var myPDFExportPreset = app.pdfExportPresets.item("myPDFpreset");
      for (var ii = layerCount - 1; ii>=0; ii--) {
              var myObjectList = new Array;
              targetLayer = targetDocument.layers[ii];
              for(var myCounter = 0; myCounter < targetLayer.pageItems.length; myCounter++){
                myObjectList.push(targetLayer.pageItems.item(myCounter));
              app.select(myObjectList);
              app.copy();
              var myDoc = app.documents.add();
              app.paste();
              myDoc.exportFile(ExportFormat.pdfType, File("c:/" + ii + ".pdf"),false);
              myDoc.close(SaveOptions.no);
