13 Replies Latest reply on May 19, 2010 2:54 PM by Monika Gause
    Seeing too much in PDF files created in CS3 AI
      Hi - I just got Illustrator CS3,  after happily using CS2 for years.
      I work "sloppy" - elements of  my design hang out over the edges of the artboard,
      and I push  things out to the side in case I need them later.
      This was  never a problem in CS2. When I would save as a PDF to send to a client,
      all they would see was the artboard (defined by page setup).
      In CS3, the  PDF I create shows  the client everything in the document!
      Even if I throw a clipping mask  on it to make the extra stuff disappear,
      the white space is in the  PDF.
      I  found if I create the PDF through the print dialog box
      the cropping works as it should, but I have no options  about
      saving with compression, which means the files can be too  big to email.
      This  is seriously messing with my workflow!!
      Can someone tell me what I  am missing here?
      Thank you.
