6 Replies Latest reply on Jul 8, 2010 10:43 AM by PrepressPro1
    Outlines keep moving on CS5 Mac  - this a big problem/bug
      In Preview mode when I use the arrows to step up/down the weight (line thickness) a horizontal line will steadily shuffle down so the top edge remains the same and the actual line shifts down. When you step down the line thickness the bottom edge stays the same and shuffles down.
      A vertical line is similar - but shifts left/right.
      Any other angle and it works correctly - ie the line stays in its position but gets thicker evenly on both sides.
      On one document I also see differences between the position of a line in preview mode and outline mode.
      This is a big problem as illustrations are being corrupted.
