0 Replies Latest reply on May 19, 2010 7:40 AM by bdog703
    Flex generates wrong webservice request XML
    bdog703 Level 1
      I have a java based web service and it seem to be working fine for most of my method calls except one of them. Here is my webservice wsdl snippet:
      <xs:element name="SaveMessageObj">
           <xs:complexType>
                <xs:sequence>
                     <xs:element maxOccurs="unbounded" name="emObjects" type="ns1:emObject"/>
                     <xs:element maxOccurs="unbounded" minOccurs="0" name="parentIds" nillable="true" type="xs:string"/>
                </xs:sequence>
           </xs:complexType>
      </xs:element>
      <xs:element name="SaveObject">
           <xs:complexType>
                <xs:sequence>
                     <xs:element maxOccurs="unbounded" ref="tns:SaveMessageObj"/>
                </xs:sequence>
           </xs:complexType>
      </xs:element>
      <wsdl:message name="SaveObject">
      <wsdl:part element="tns:SaveObject" name="SaveObjectRequest">
          </wsdl:part>
      </wsdl:message>
      <wsdl:operation name="SaveObject">
      <wsdl:input message="tns:SaveObject" name="SaveObject">
          </wsdl:input>
      <wsdl:output message="tns:SaveObjectResponse" name="SaveObjectResponse">
          </wsdl:output>
      <wsdl:fault message="tns:SaveObjectFault" name="SaveObjectFault">
          </wsdl:fault>
      </wsdl:operation>
      I created the web service client code using the data services wizard in Flash 4 builder. Here is my code to call the web service:
      _service = new EMServices();
      var req:SaveMessageObj = new SaveMessageObj();
      req.emObjects = new ArrayCollection([emObject]);
      if (parentId != null)
      req.parentIds = new ArrayCollection([parentId]);
      _service.SaveObject(new ArrayCollection([req]));
      When I make the call with the above code, the XML that gets send over the wire is as follows:
      <SOAP-ENV:Body>
      <tns:SaveObject  xmlns:tns="http://sample.com/digitalmedia/EMServices">
      <tns:SaveMessageObj>
      <emObjects/>
      <parentIds>[object SaveMessageObj]</parentIds>
      </tns:SaveMessageObj>
      </tns:SaveObject>
      </SOAP-ENV:Body>
      It looks as if the service could not generate the XML properly since the parentIds contains the whole object as "[object SaveMessageObj]". Any ideas what might be wrong here, it looks like a bug but I can't be sure. I'm not using Flex 4 SDK, I'm using 3.5 SDK for this specific project due to some client limitations.
      Thanks!
