6 Replies Latest reply on Mar 2, 2012 5:37 AM by Jayesh Sharma
    TextSnapshot problem
    Yevhen Runts Level 1
      I'm using textSnapshot property of DisplayObjectContainer to select static text in loaded in runtime SWF.
      The interesting issue is if call  _textSnapshot = getTextSnapshot(_swfLoder); twice static text in swf will be not selected.
      Please comment/uncoment row after "       //!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!"and test application.
      Test SWF file you can download at http://dl.dropbox.com/u/2147606/test.swf
      Are there any ideas why this happens? There are several SWFs and I can not read all textSnapshots at once so this problem is very critical for me.
      Sample code:
      <mx:Application
          xmlns:mx="http://www.adobe.com/2006/mxml"
          layout="absolute"
          minWidth="955" minHeight="600"
          creationComplete="init()">
          <mx:Script>
              <![CDATA[
                  import mx.controls.SWFLoader;
                  private var  _textSnapshot: TextSnapshot;
                  private var _swfLoder: SWFLoader;
                  private function init(): void
                      var url: String = "test.swf";
                      _swfLoder = new SWFLoader();
                      _swfLoder.addEventListener(Event.COMPLETE , completeHandler);
                      _swfLoder.load(url);
                  private function completeHandler(event: Event): void
                      _swfLoder = event.target as SWFLoader;
                      _swfLoder.y = 0;
                      _swfLoder.x = 0;
                      addChild(_swfLoder);
                      //Comment to see highlighting
                      //_textSnapshot = getTextSnapshot(_swfLoder);
                      var searchText: String = "a";
                      var startPosition: int = 0;
                      startPosition = _textSnapshot.findText(startPosition, searchText, false);
                      _textSnapshot.setSelected(0, _textSnapshot.charCount, false);
                      while (startPosition >= 0)
                          _textSnapshot.setSelected(startPosition, startPosition + searchText.length, true);
                          startPosition += searchText.length;
                          startPosition = _textSnapshot.findText(startPosition, searchText, true);
                  private function getTextSnapshot(loader: SWFLoader): TextSnapshot
                      var textSnapshot: TextSnapshot;
                      if (loader.content != null)
                          var movieClip: MovieClip = loader.content as MovieClip;
                          if (movieClip != null)
                              textSnapshot = (movieClip as DisplayObjectContainer).textSnapshot;
                      return textSnapshot;
          </mx:Script>
      </mx:Application>
        • 1. Re: TextSnapshot problem
          Volodymyr Styranivskyy
          I fixed this issue by storing previous snapshots into array. I'm not sure why you should do this maybe it is connected to GC. But anyway following example works fine.
          <mx:Application
          layout="absolute"
          <mx:Script>
          <![CDATA[
          // SArray of snapshots
          private var  textSnapshots: Array = new Array();
          var url: String = "http://dl.dropbox.com/u/2147606/test.swf";
          _swfLoder.y = 0;
          _swfLoder.x = 0;
          // Store previous snapshot
          textSnapshots.push(_textSnapshot);
          </mx:Script>
          </mx:Application>
          • 2. Re: TextSnapshot problem
            Thanks a lot) It helps me to solve problems i had.
            • 3. Re: TextSnapshot problem
              JSujubala-nZao4n
              Hi Yevhen Runts
              i have using your code but my swf file is locally loaded in my application, although i could not get textSnapshot, error is occured
              The Error is:Error #1009: Cannot access a property or method of a null object reference.
              the error occured in this line(startPosition = _textSnapshot.findText(startPosition, searchText, false)).
              Coding is
              <mx:Application
              layout="absolute" minWidth="955" minHeight="600"
                  <mx:Script>
                  <![CDATA[
                          _swfLoder.y = 0;
                          _swfLoder.x = 0;
                          var searchText: String = "S";
                  </mx:Script>
              </mx:Application>
              Please help me
              • 4. Re: TextSnapshot problem
                JSujubala-nZao4n Level 1
                Hi Yevhen Runts
                First of all i m very sorry, my mistake is i am using as2 swf files, but another problem is the setselected color is not working, so please help me
                • 5. Re: TextSnapshot problem
                  Hi Yevhen Runts
                  Hi sorry i solve this problem its working fine, my mistake is the swf text is not embeded, anyway thanks lot
                  • 6. Re: TextSnapshot problem
                    Jayesh Sharma
                    Hi Volodymyr,
                    Thanks a lot for the posting the answer it worked for me
                    My only concern is that you are not removing textsnapshots you are adding into the array. So after some time will it not cause memory leaking?
