0 Replies Latest reply on May 19, 2010 12:20 PM by drjellsworth
    When running TestRunner with FlexUnit 0.9, the TestRunnerBase GUI never loads.
    drjellsworth
      I am trying to get a couple simple unit tests working for my Flex  Project.  I created and added a .as file to my project which contains a class with a method 'testBlah'.  The testBlah method just contains assertTrue("blah",true);
      Then I created a TestRunner.mxml file in the same project.  It is as follows:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns="*"
                      xmlns:flexunit="flexunit.flexui.*"
                      creationComplete="onCreationComplete()">
          <mx:Script>
              <![CDATA[
                  import flexunit.framework.TestSuite;
                  // Create the test suite and run the tests
                  private function onCreationComplete():void
                        testRunner.test = createSuite();
                        testRunner.startTest();
                  // Creates the test suite to run
                  private function createSuite():TestSuite {
                        var testSuite:TestSuite = new TestSuite();
                        testSuite.addTestSuite( InputManagerTest );
                        return testSuite;
          </mx:Script>
          <!-- FlexUnit GUI Component -->
          <flexunit:TestRunnerBase id="testRunner" width="100%" height="100%" />
      </mx:Application>
      When compiled, TestRunner.html is created.  When I load TestRunner.html in my web browser, The FlexUnit TestRunnerBase GUI component never loads.  What am I doing wrong?  Any help would be much appreciated.  Thank you.
