5 Replies Latest reply on Jun 3, 2010 10:52 AM by cyber0897
    how do i send variables to a flash file using swfloader???
    cyber0897 Level 1
      hey guys... so im trying to load a swf using the SWFLoader, and i need to some how send a variable to that swf, and in that swf i need to capture that variable if that makes any sence...
      the swf is made in flash, and a function init is called everytime the swf loads...
      in that init function in the flash actionscript i need to capture the variable i send from flash builder....
      so far i have the following code...
      in this code i have no idea on how to send variables to my swf
              var swfLdr:SWFLoader = new SWFLoader();
              swfLdr.horizontalCenter = 0;
              swfLdr.verticalCenter = 0;
              swfLdr.source = "http://test-broadcast.apxinsider.com/Content/swf/office_weekly_UF.swf";
              swfLdr.addEventListener(Event.INIT, swfLoaded);
              swfLdr.load();
      now i was htining i could do somehting like office_weekly_UF.swf?id=1304 or somehting... but if i do that, how do i capture this in my swf???
      any thing would help! thank you so much!
        • 2. Re: how do i send variables to a flash file using swfloader???
          nishadmusthafa Level 2
          I'll put up what i think is the answer. Do tell me if this is what you are looking for. When I created the swf in Flash Pro.This is the code I used
          var keyStr:String;
          var paramObj:Object = LoaderInfo(this.root.loaderInfo).parameters;
          for (keyStr in paramObj) {
          urlText.text = String(paramObj[keyStr]);
          urlText is a text box whose content text is passed as a URL parameter. The parameters can be retrieved from paramObj. Is that what you meant by capturing the variables?
          Then on the flex side, this is the code i used to display from SWFloader
                     import mx.controls.SWFLoader;
                      private var swfLdr:SWFLoader;
                      private function startSWF():void
                          swfLdr = new SWFLoader();
                          swfLdr.source = "MySWF.swf?urlText=verbose";
                          addElement(swfLdr);
          I hope this helps.
          Nishad
          • 3. Re: how do i send variables to a flash file using swfloader???
            cyber0897 Level 1
            hi Nishad, well i looked a lot into this, and i found out that after loading the swf i am able to access public function and variables after the swf has loaded, therefore i just modified all the swfs to fit my need, where i just ended up doing somehting like the following
                      swfLdr.source = "/content/swf/" + tempFileName;
                      swfLdr.addEventListener(Event.COMPLETE, swfLoaded);
                      swfLdr.load();
            private function swfLoaded(event:Event):void{
                 swfLdr.removeEventListener(Event.COMPLETE, swfLoaded);
                 childSwf = new MovieClip();
                 childSwf = event.target.content;
                 childSwf.init(1);
            • 4. Re: how do i send variables to a flash file using swfloader???
              Oh.. Nice. This is good info. If you've resolved any of the other issues like the sandbox issue, do post your findings.
              Nishad
              • 5. Re: how do i send variables to a flash file using swfloader???
                cyber0897 Level 1
                i havent read thru the sandbox article yet, but i just ended up moving my release build swf to the server to get around that problem....
