0 Replies Latest reply on May 19, 2010 5:54 PM by Jason Szeto
    [svn:fx-trunk] 16236: Form Feature Work
    Jason Szeto Level 3
      Revision: 16236
      Revision: 16236
      Author:   jszeto@adobe.com
      Date:     2010-05-19 17:54:54 -0700 (Wed, 19 May 2010)
      Log Message:
      Form Feature Work
      Merging in Form classes from the private sandbox. All spec'ed functionality has been implemented.
      QE notes: none
      Doc notes: Needs ASDoc comments
      Bugs: none
      Reviewer: Hans, Kevin
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/defaults.css
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/ToolTipManagerImpl.as
          flex/sdk/trunk/frameworks/projects/spark/bundles/en_US/layout.properties
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/SparkClasses.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ButtonBase.a s
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableCom ponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableTex tBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/TextBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/LayoutElementHe lper.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/FocusSkin.as
          flex/sdk/trunk/frameworks/spark-manifest.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Form.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/FormHeading.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/FormItem.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/ConstraintLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/FormItemLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/FormLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/FormHeadingSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/FormItemSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/FormSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/StackedFormHeadingSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/StackedFormItemSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/assets/
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/assets/ErrorIndicator.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/assets/RequiredIndicator.p ng
      Removed Paths:
      Property Changed:
          flex/sdk/trunk/
