2 Replies Latest reply on May 20, 2010 3:28 AM by boom-shanka
    Hybrid CD not running Air app
    boom-shanka
      Hello ... having trouble with a hybrid CD i'm trying to burn in Toast ... i'm using a Mac .
      I've built my image (dmg) for the Mac side and it works fine ... I'm using a sidecar install of the Air framework which leads onto installing my application once finished .
      I've tested this dmg and it all works ok .
      But ... when i burn a Hybrid CD using this image as the Mac partition the Air framework + app refuse to work anymore .
      I double click the sidecar Air installer icon and absolutely nothing happens - nothing starts/loads, no errors, nothing .
      What is causing my once functioning image to die ?  The PC side of the hybrid works ok ... but i need the Mac side to work as well .
      Cheers,
      Steve
        • 1. Re: Hybrid CD not running Air app
          boom-shanka Level 1
          I've narrowed it down to the Adobe Air Installer application ...
          I copied my CD contents to a test folder & by process of elimination have found this app to be the culprit .
          When i replaced with a non-'burnt' version the Air install went ahead as usual ...
          ... so somewhere between me clicking 'Burn CD' & clicking the icon this file is been damaged / modified .
          Ok... i've opened the Adobe Air Installer application package up and ...any content files with long filenames have been renamed .
          Wonderful ... so anything over 24(+?) or so chars is going to be truncated with #9C or similar - which breaks things ... including Air.
          Why aren't long file names being copied across ?  I don't know where the problem lies now .
          • 2. Re: Hybrid CD not running Air app
            boom-shanka Level 1
            Well it looks like its not really an Air issue ... more a file system naming convention thing issue ... which is a pain as there doesn't seem to be any clear definite answers out there as to how to get a hybrid CD with shared files to work .
            My dmg is HFS+ . My iso is Joliet .
            Why am i still getting file name problems ?
            Every now and again i get a final disk image that actually 'works' .
            But when i try to replicate the steps i took to make it, failure .  Painful
