1 Reply Latest reply on May 19, 2010 10:40 PM by David_F57
    XLM playlist issue
    agent-o2
      I'm working on an app that plays video's from an XML playlist using videoDisplay. everything works fine in OSX but when the swf is played on a windows machine the player throws and error 1000 can't find the flv
      i've tried specifing the path various ways in the xml, adding single quotes around the file name in the tag seemed to make windows work but broke OSX.
      Anyone have any insight into this?
        • 1. Re: XLM playlist issue
          David_F57 Level 5
          hi,
          this could be  a few things, xml format (spaces, upper/lower case etc.), how the xml is retrieved, is pathing relative. without seeing the xml or the code used to read it its not possible to give a reasonable help with your problem.
          David
