1 Reply Latest reply on May 20, 2010 11:35 AM by oldMster
    Sending a KEY : VALUE variable pair to a HTTPSERVICE?
    mumcs01
      So I"m working on sending a key and value to a PHP script. Simple. So below works if I define the KEY as a literal. (KEY1). But if I change the button publish to  <mx:Button label="Publish Changes" click="getConfig.send( { keytoinsert.text : valuetoinsert.text } )" , I get 'Expecting right paren before colon.' compiler error. Why can't I use a variable as a Key value to the left of the colon?
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
      <mx:HTTPService id="getConfig" url="http://10.101.50.60/xmlpost.php"
      method="POST" showBusyCursor="true" resultFormat="e4x">
      </mx:HTTPService>
        <mx:FormItem label="Key:">
          <mx:TextInput id="keytoinsert" />
         </mx:FormItem>
         <mx:FormItem label="Value:">
          <mx:TextInput id="valuetoinsert" />
         </mx:FormItem>
      <mx:Button label="Publish Changes" click="getConfig.send( { KEY1 : valuetoinsert.text } )" />
      </mx:Application>
        • 1. Re: Sending a KEY : VALUE variable pair to a HTTPSERVICE?
          oldMster Level 3
          I don't think you can do it in the MXML declaration, but you can do it in a script:
          <mx:Script>
               <![CDATA[
                    private function sendit():void {
                         if (keytoinsert != NULL ) {
                              if (keytoinsert.text != "") {
                                   var params:Object = new Object();
                                   params[keytoinsert.text] = valuetoinsert.text;
                                   getConfig.send(params);
          </mx:Script>
          </mx:HTTPService>
             </mx:FormItem>
             </mx:FormItem>
          <mx:Button label="Publish Changes" click="sendit( );" />
          </mx:Application>
