1 Reply Latest reply on May 20, 2010 9:08 AM by Ansury
    JSON problem with array
    Handycam Level 1
      I have an array I am trying to json encode and send to a php file.  It would seem from the response from my php file that the second-level array members are recognized but empty.
      The array I am working with is:
      0,0,community-recipes,This is the post content lorem ipsum dolor sit amet,This is the post excerpt,Starter Salads,Serves four,/create-your-own-menu/backyard-bbq.aspx,some tag,another tag,make ahead,2205,1013,6229,11028,11030,11033,11039,11039
      There are 3 arrays inside this long one:
      2205,1013,6229
      My PHP returns:
      sonSendData=[0,0,"community-recipes","This is the post content lorem ipsum dolor sit amet","This is the post excerpt","Starter Salads","Serves four","/create-your-own-menu/backyard-bbq.aspx",[{},{},{}],[{},{}],[{},{},{},{},{}],"11039"]
      <pre>
      Array
          [0] => 0
          [1] => 0
          [2] => community-recipes
          [3] => This is the post content lorem ipsum dolor sit amet
          [4] => This is the post excerpt
          [5] => Starter Salads
          [6] => Serves four
          [7] => /create-your-own-menu/backyard-bbq.aspx
          [8] => Array
                  [0] => stdClass Object
                  [1] => stdClass Object
                  [2] => stdClass Object
          [9] => Array
          [10] => Array
                  [3] => stdClass Object
                  [4] => stdClass Object
          [11] => 11039
      </pre>
      As you can see, those arrays are present buy empty.  Here's the PHP:
      <?php
      print_r($_POST);
      while (list($k, $v) = each($_POST)) {
      echo $k . '=' . urldecode($v);
      $json = urldecode($_POST['jsonSendData']);
      $arr = json_decode($json);
      $txt = print_r($arr, true);
      <pre>
      <?php echo $txt; ?>
      </pre>
        • 1. Re: JSON problem with array
          Ansury Level 3
          I guess this probably doesn't help, so forgive me if this is impossible for whatever reason, but is there a reason you're using a protocol that's inferior to AMF?  That seems like an awful lot of needless pain when you could be using any of :
          Zend AMF, AMFPHP, WebORB for PHP, or SabreAMF
