0 Replies Latest reply on May 20, 2010 10:14 AM by jaydub17
    NetGroup Connection Not Reporting Neighbor Connected Event
    jaydub17
      Our app was working yesterday and now for whatever reason we don't see a neighbor.connected.success event and the peers don't seem to be responding to eachother.  you can see our demo at: http://gab-err.appspot.com/a/P2PMulti.html,  any two pc's connecting will be use the same group name: group1.   the NetGroup.Connect.Success event fires successfully but that's it, the Multicast.Stream.Publish and Neighbor.Connect.Success never fire. thanks guys.
      Here's our source for the connection:
      private const SERVER:String = 'rtmfp://stratus.adobe.com/5b6708e640918da6e8586117-977937ad98db/';
      public var seq_num:int = 0;
      public function MulticastP2PConnection()
      super();
      _eventDispatcher = new EventDispatcher();
      Debug.warning('latest::MulticastP2PConnection');
      Debug.warning('build 1636');
      public function get primary():Boolean
      return _primary;
      public function set primary(value:Boolean):void
      Debug.warning('setting primary ' + value);
      _primary = value;
      public function init(group_name:String) {
      this.group_name = group_name;
      // start outgoing connection
      net_connection = new NetConnection();
      net_connection.addEventListener(NetStatusEvent.NET_STATUS, on_net_status);
      net_connection.connect(SERVER);
      public function close_all_connections():void {
      if (net_connection != null) {
      net_stream.close();
      net_stream = null;
      net_group.close();
      net_group = null;
      net_connection.close();
      net_connection = null;
      if (incomming_connection != null) {
      incomming_stream.close();
      incomming_stream = null;
      incomming_connection.close();
      incomming_connection = null;
      private function on_net_status(evt:NetStatusEvent):void {
      Debug.log ("on_net_status " + evt.info.code);
      if (net_group != null) {
      Debug.log('estimated member count ' + net_group.estimatedMemberCount);
      switch(evt.info.code)
      case "NetConnection.Connect.Success":
      on_net_connected(evt);
      break;
      case "NetStream.Connect.Success":
      on_stream_connected(evt);
      break;
      case "NetGroup.Connect.Success":
      on_group_connected(evt);
      break;
      case "NetGroup.Neighbor.Connect":
      on_neighbor_connected(evt);
      break;
      case "NetGroup.Posting.Notify":
      on_posting_notify(evt.info.message);
      break;
      case "NetGroup.MulticastStream.PublishNotify":
      on_publish_notify(evt);
      break;
      case "NetGroup.Neighbor.Disconnect":
      this.dispatchEvent(new P2PEvent(P2PEvent.NEIGHBOR_DISCONNECTED, evt.info));
      break;
      private function on_net_connected(evt:NetStatusEvent = null):void
      group_spec = new GroupSpecifier(group_name);
      group_spec.multicastEnabled = true;
      group_spec.serverChannelEnabled = true;
      group_spec.postingEnabled = true;
      //Debug.log ("group id: " + group_spec.groupspecWithAuthorizations());
      net_stream = new NetStream(net_connection, group_spec.groupspecWithAuthorizations());
      net_stream.multicastWindowDuration = .2;
      net_stream.addEventListener(NetStatusEvent.NET_STATUS, on_net_status);
      net_group = new NetGroup(net_connection, group_spec.groupspecWithAuthorizations());
      net_group.addEventListener(NetStatusEvent.NET_STATUS, on_net_status);
      this.dispatchEvent(new P2PEvent(P2PEvent.NET_CONNECTED, evt.info));
      private function on_stream_connected(evt:NetStatusEvent = null):void
      Debug.warning ("on_net_stream_connected");
      net_stream.client = this;
      this.dispatchEvent(new P2PEvent(P2PEvent.STREAM_CONNECTED));
      private function on_neighbor_connected(evt:Event = null):void
      ready();
      public function ready(evt:Event = null):void
      Debug.warning('ready, am i primary? ' + this.primary);
      post_system_message({ stream_id:GaberrModel.getInstance().stream_id,
      status:'ready',
      primary:this.primary,
      topic:GaberrModel.getInstance().room.topic,
      prejudice:GaberrModel.getInstance().user.prejudice
      public function cam_activity(evt:Event = null):void
      //Debug.log('cam acitivty');
      //post_system_message({stream_id:GaberrModel.getInstance().stream_id,status:'ready'});
      private function on_posting_notify(message:Object):void
      //Debug.log ("on_posting_notify " + message);
      Debug.object(message);
      // if this node is being pinged then setup the incomming stream as well
      Debug.log('system ' + (message.system == 'system'));
      Debug.log('status ' + (message.status == 'ready'));
      if (message.user == 'system') {
      this.incomming_stream_name = message.stream_id;
      this.dispatchEvent(new P2PEvent(P2PEvent.SYSTEM_POST, message));
      //setup_incomming_stream();
      if (message.status == 'ready') {
      Debug.error('ready::Dispatching neighbor connected');
      this.dispatchEvent(new P2PEvent(P2PEvent.NEIGHBOR_CONNECTED));
      } else {
      this.dispatchEvent(new P2PEvent(P2PEvent.GROUP_POST, message));
      this.system_data = evt.info.message;
      Debug.warning('system message recieved');
      Debug.object(system_data);
      if (!this.primary) {
      // post return handshake
      //post_system_message(system_data);
      // setup stream from primary user
      //this.incomming_stream_name = system_data.streams[1];
      //Debug.log('incomming_stream_name ' + incomming_stream_name);
      this.dispatchEvent(new P2PEvent(P2PEvent.NEIGHBOR_CONNECTED, evt.info));
      } else {
      this.dispatchEvent(new P2PEvent(P2PEvent.GROUP_POST, evt.info));
      private function on_publish_notify(evt:NetStatusEvent = null):void
      //Debug.warning('publish notify???');
      this.incomming_stream_name = evt.info.name;
      private function setup_incomming_stream(evt:NetStatusEvent = null):void
      Debug.log('setup_incomming_stream ');
      net_connection.removeEventListener(NetStatusEvent.NET_STATUS, on_net_status);
      net_connection.addEventListener(NetStatusEvent.NET_STATUS, on_incomming_net_status);
      //incomming_stream = new NetStream(net_connection, NetStream.DIRECT_CONNECTIONS);
      incomming_stream = new NetStream(net_connection, group_spec.groupspecWithAuthorizations());
      incomming_stream.addEventListener(NetStatusEvent.NET_STATUS, on_incomming_net_status);
      incomming_stream.client = this;
      private function on_incomming_net_status(evt:NetStatusEvent):void {
      Debug.log ("on_incomming_net_status " + evt.info.code);
      Debug.object(evt.info);
      Debug.log ("net_connection connected");
      //on_incomming_net_connected();
      break;
      on_incomming_stream_connected();
      break;
      private function on_incomming_stream_connected():void
      // load other stream
      Debug.log ("on_incomming_stream_connected, creating video player");
      this.dispatchEvent(new P2PEvent(P2PEvent.INCOMMING_STREAM_CONNECTED));
      public function post_message(username:String, val:String):void {
      var mes:Object = {};
      mes.user = username;
      mes.text = val;
      mes.sequence = seq_num++;
      mes.sender = net_connection.nearID;
      var status:String = net_group.post(mes);
      Debug.log('post status ' + status);
      public function post_system_message(mes:Object):void {
      mes.user = 'system';
      private function on_group_connected(evt:NetStatusEvent = null):void
      Debug.log ("joined group! " + group_name);
      this.dispatchEvent(new P2PEvent(P2PEvent.GROUP_CONNECTED, group_name));
