1 Reply Latest reply on May 20, 2010 1:51 PM by Sky Chief
    Template: Optional Editable Background - How?
    Sky Chief
      Desire: Use templated page, but be able to change background separately if needed.
      I would like to be able to create a page using template and then be able to edit the background image and save it.
      Research: I see that there is a way to make an attribute editable, but not sure how it workes. Attempted to follow example posted, but didn't work. Wondering if anyone has a clear simple way of explaining this specific thing. Realively new to all of this, and trying to save time on this 'wish' for other hurdles.
      Here is an example of what I was attempting:
      <style type="text/css" bodybackground = [suspect it should enter a url here??] >
      The default background image will be fine for some areas, but just want the option to change it.
      Thanks for the help
      Keith
      ps. Using DWCS5
        • 1. Re: Template: Optional Editable Background - How?
          Sky Chief Level 1
          Okay, after tinkering, figured it out..
          While in the templage page - Choose MODIFY | TEMPLATES | MAKE ATTRIBUTES EDITABLE...
          Click ADD
          I used: background-image for the name
          Enter the other attibutes and save.
          Create a page using the template and choose MODIFY | TEMPLATE PROPERTIES
          There you can browse and insert your background image path.
