3 Replies Latest reply on May 23, 2010 11:08 AM by UbuntuPenguin
    RTMP Channel failing to send over 10 MB size on each collection
    NageswarM
      Hi, I am using RTMP channel for communicating with Java services.  RTMP is failing when the collection size is more than 10 MB.  Are there any ways to increase the size?  I found couple of tags in forums but none them working.
      <channel-definition id="my-rtmp" class="mx.messaging.channels.RTMPChannel">
          <endpoint url="rtmp://localhost:2038"
              class="flex.messaging.endpoints.RTMPEndpoint" />
          <properties>
              <idle-timeout-minutes>60</idle-timeout-minutes>
              <client-to-server-maxbps>100K</client-to-server-maxbps>
              <server-to-client-maxbps>100K</server-to-client-maxbps>
          </properties>
      </channel-definition>
      When I try to deploy it is giving the below error:
      <Servlet: "MessageBrokerServlet" failed to preload on startup in Web application: "tpvincispain.war".
      javax.servlet.UnavailableException: Unrecognized tag found in <properties>.  Please consult the documentation to determine if the tag is invalid or belongs inside of a different tag:
        '/server-to-client-maxbps' in channel with id: 'my-rtmp' from file: services-config.xml
      I really appreciate any help in this regard.
      Nageswar
