0 Replies Latest reply on May 20, 2010 3:24 PM by kevinklin
    [svn:fx-trunk] 16267: Added better baseline support for ConstraintLayout.
    kevinklin Adobe Employee
      Revision: 16267
      Revision: 16267
      Author:   klin@adobe.com
      Date:     2010-05-20 15:24:53 -0700 (Thu, 20 May 2010)
      Log Message:
      Added better baseline support for ConstraintLayout. ConstraintRow's now have a baseline property. It can either be a number or of the form "maxAscent:x". In the first case, it will position elements at that y-pixel value in the row based on their baseline position.  Otherwise, it first aligns elements to the maximum baseline position of the elements in the row, and then, positions elements based on the pixel value provided. This support allows elements with different baselinePositions to be aligned more easily.
      QE notes: No
      Doc notes: No
      Bugs: No
      Reviewer: Jason
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/utilityClasses/ConstraintR ow.as
          flex/sdk/trunk/frameworks/projects/spark/bundles/en_US/layout.properties
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/ConstraintLayout.as
