3 Replies Latest reply on May 21, 2010 7:20 AM by RicardoFressa
    Flex 3 + Java + BlazeDS
    RicardoFressa
      Hello, I'm trying to make the interaction between Flex 3 + Java + BlazeDS but unfortunately I'm not getting.
      I am using Eclipse Ganymede 3.4.2, the plug-in with the Flex SDK 3.2, and BlazeDS 3.2.0.3978
      What happens is an error that Flex 3 does not find the main file of my project, after I put the folders Libs Flex, and the new web.xml file in my project.
      HTTP Status 404 -
      type Status report
      message
      The description Requested resource () is not available.
      and the error console:
      May 20, 2010 9:02:13 PM org.apache.catalina.core.AprLifecycleListener init
      INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre6\bin;.;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\Sy stem32\WindowsPowerShell\v1.0\;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\DTS\Binn\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Common Files\Ahead\Lib\;C:\Program Files\Common Files\Ahead\Lib\;C:\Program Files\Common Files\Ahead\Lib\;C:\Program Files\Common Files\Ahead\Lib\
      May 20, 2010 9:02:13 PM org.apache.tomcat.util.digester.SetPropertiesRule begin
      WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.j2ee.server:Integra_java_flex_blazeds' did not find a matching property.
      May 20, 2010 9:02:13 PM org.apache.coyote.http11.Http11Protocol init
      INFO: Initializing Coyote HTTP/1.1 on http-8080
      May 20, 2010 9:02:13 PM org.apache.catalina.startup.Catalina load
      INFO: Initialization processed in 793 ms
      May 20, 2010 9:02:13 PM org.apache.catalina.core.StandardService start
      INFO: Starting service Catalina
      May 20, 2010 9:02:13 PM org.apache.catalina.core.StandardEngine start
      INFO: Starting Servlet Engine: Apache Tomcat/6.0.26
      May 20, 2010 9:02:13 PM org.apache.catalina.loader.WebappClassLoader validateJarFile
      INFO: validateJarFile(C:\eclipse\workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\ wtpwebapps\Integra_java_flex_blazeds\WEB-INF\lib\servlet.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
      May 20, 2010 9:02:14 PM org.apache.catalina.core.StandardContext listenerStart
      SEVERE: Error configuring application listener of class flex.messaging.HttpFlexSession
      java.lang.ClassNotFoundException: flex.messaging.HttpFlexSession
      at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1516)
      at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1361)
      at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3915)
      at org.apache.catalina.core.StandardContext.start(StandardContext.java:4467)
      at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
      at org.apache.catalina.core.StandardHost.start(StandardHost.java:785)
      at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
      at org.apache.catalina.core.StandardService.start(StandardService.java:519)
      at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
      at org.apache.catalina.startup.Catalina.start(Catalina.java:581)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
      at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
      SEVERE: Skipped installing application listeners due to previous error(s)
      May 20, 2010 9:02:14 PM org.apache.catalina.core.StandardContext start
      SEVERE: Error listenerStart
      SEVERE: Context [/Integra_java_flex_blazeds] startup failed due to previous errors
      Here is my web.xml
      <?xml version="1.0" encoding="UTF-8"?>
      <!DOCTYPE web-app PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN" "http://java.sun.com/dtd/web-app_2_3.dtd">
      <web-app>
          <display-name>BlazeDS</display-name>
          <description>BlazeDS Application</description>
          <!-- Http Flex Session attribute and binding listener support -->
          <listener>
              <listener-class>flex.messaging.HttpFlexSession</listener-class>
          </listener>
          <!-- MessageBroker Servlet -->
          <servlet>
              <servlet-name>MessageBrokerServlet</servlet-name>
              <display-name>MessageBrokerServlet</display-name>
              <servlet-class>flex.messaging.MessageBrokerServlet</servlet-class>
              <init-param>
                  <param-name>services.configuration.file</param-name>
                  <param-value>/WEB-INF/flex/services-config.xml</param-value>
             </init-param>
              <load-on-startup>1</load-on-startup>
          </servlet>
          <servlet-mapping>
              <url-pattern>/messagebroker/*</url-pattern>
          </servlet-mapping>
          <welcome-file-list>
              <welcome-file>Integra_java_flex_blazeds.html</welcome-file>
              <welcome-file>index.htm</welcome-file>
          </welcome-file-list>
          <!-- for WebSphere deployment, please uncomment -->
          <resource-ref>
              <description>Flex Messaging WorkManager</description>
              <res-ref-name>wm/MessagingWorkManager</res-ref-name>
              <res-type>com.ibm.websphere.asynchbeans.WorkManager</res-type>
              <res-auth>Container</res-auth>
              <res-sharing-scope>Shareable</res-sharing-scope>
          </resource-ref>
      </web-app>
