5 Replies Latest reply on May 25, 2010 4:51 PM by Tom Ruark
    BridgeTalk and localization
    xbytor2 Level 4
      I have CS3, CS4, and CS5 all installed. I run this bit of code from the docs
         BridgeTalk.getSpecifier("photoshop", 0, "en_us");
      I only get the correct answer from CS3 apps. CS4 and CS5 always return null. If I drop off the locale, CS4 and CS5 magically work.
      Usually, I wouldn't care. But I kinda need to support multiple localizations in PS.
      Anybody else seeing anything different?
        • 1. Re: BridgeTalk and localization
          xbytor2 Level 4
          As a follow on, these don't work with en_US or de_DE:
          BridgeTalk.launch("photoshop-12.0-de_DE");
          BridgeTalk.launch("photoshop-12-de_DE");
          BridgeTalk.launch("photoshop-0-de_DE");
          The only thing that does work is
          BridgeTalk.launch("photoshop-12");
          So, it looks like things are either broke or have changed (a lot) and just aren't documented.
          -X
          • 2. Re: BridgeTalk and localization
            Tom Ruark Adobe Employee
            Photoshop is multi-lingual starting with CS4. You can find out what language it is in after it is running by using app.locale. You will get no language information from the specifier for CS4 and newer via BridgeTalk.
            The other difficult part is that Photoshop is 32 and 64 bit on Macintosh and Windows so the specifiers are 11.032 and 11.064. This was an easy way for the 64 bit version to win if you don't specify which version you want. You get the highest version with a bare specifier, "photoshop", and that would translate to the 64 bit app if you are on 64 bit hardware.
            The examples in the documentation need to get updated for "photoshop" but they do work and are correct for other suite applications that support BridgeTalk.
            • 3. Re: BridgeTalk and localization
              xbytor2 Level 4
              Thanks for the info, Tom. And it's good to see you spending time here :)
              But I still have the underlying problem where I have a Bridge script that needs to launch a PS in a particular locale. Since the BridgeTalk locale specifiers don't work for PS, and setting the UI Language (aka Locale) in PS preferences is ignored I'm very stuck. Currently, I have to tell users that they need to manually need to specify the locale and then run the script; I can't batch across locales.
              Any pointers would be very much appreciated.
              BTW, the Script Listener does generate code for changing locales. It's just silently ignored when you execute that code from a script.
              -X
              • 4. Re: BridgeTalk and localization
                Changing the locale and then restarting Photohsop doesn't work? Let's log that bug. I thought locale changes only worked after a restart of Photoshop.
                And even if we fix that you would have to Launch, change/check locale, relaunch if needed, then run your script. Looks like you have a fun problem to solve. What exactly are you trying to do? Maybe another approach would work. Are you dealing with folks that change their locale a lot?
                • 5. Re: BridgeTalk and localization
                  xbytor2 Level 4
                  Correct. Changing the locale from JS does not work. Even after a restart.
                  Not a problem. The app is driven from a top-level Bridge script because of all of the "interesting" things I have to do to/with PS.
                  NDA :)  I'll drop you a line.
                  -X
